Thin Metal Axel Shaft (Anti-Rust) Gaskets
Anyone recall these and are there any available in the aftermarket.
Thx
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
I should have a couple originals if you need em
10.00 mailed |
Are those different for nodular than regular rears
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
Steel shim
Here are a couple of the steel shims
Scott |
That's what I recall.
Funny how these thing just fade away. I was trying to remember these and recalled them but then couldn't find any in my bins so started droughting my recollection. Scott, Since I can't locate ones I know I have/had I'd be interested. Shoot me an address and I'll sent out payment. Thanks.
I bought mine from a local part store about 4 years ago Felpro part number 13394
Those are the Paper gaskets for the flange plate.
IIRC the Metal ones go between the backing plate and axle tube.
1964-69 8.2" uses #9777865 gasket to axle housing, and #9774551 gasket for the bearing retainer. Obsolete parts.
1970-72 8.2" uses an outer seal, thus no such gaskets. |
FOUND THEM
Scott,
Thanks for the offer but I finally found mine.
Thread Tools | |
Display Modes | |
