Too bad they didnt put the Pontiac SD 3.0 DOHC engine in many GM cars, it probably would have been much better then the headgasket eating Olds Quad 4 : http://www.highperformancepontiac.co...ger/index.html
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
GM sold the licensing and rights to the SD4 to another company that is still making the SD4 parts. They still use them in ARCA racing. So if you want a little more power for the Astre (I had a 1976 hatchback that was painted carosel red with white racing stripes) here is their website: http://www.kansasracingproducts.com/...the_Block.html
Happiness isn't around the corner... Happiness IS the corner. 1986 Fiero SE Now ZZ4 Powered! |
Hey now I made alot of money doing those headgaskets while at the dealership.I didnt make much off the 2.5L other than timing covers/chain tensioners,and v/c gaskets. They were to reliable of an engine. Craig |
One of those wagons with a 455 has to be flat-out fun!
ARROWHEAD ADDICTION: An incureable disease contracted from the pointed edge of classic pontiacmuscle; all consuming, taking over mind, body and soul. |
Thanks for all the info guys!
I guess I should listen to my father about the paint then And by the way, this engine is not stock. The guy I bought it from used to race his S10's. It has some head work done & a beefier cam. Jory wants to do more & get an even beefier cam
Come on Mom, lemme drive!! |
I'd paint it black to hide the oil leaks. The valve cover gasket was the weak point on those engines. They leak like a Detroit Diesel. With some care and maybe not, they run forever and a day.
I still think you should shove a Turbo V-6 in it out of a Grand National, in stock form it'd scream, with a little more boost, some injectors and a few other mods it'd run 11's in street trim and get 20+ mpg. Mike
The only other issue with the iron dukes is the Plastic timing gear, the one on my 77 Astre Formula just snapped a few weeks ago. I don't think it will move under the 2.5's power again.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
And NOTHING leaks oil like a Detroit diesel !
Oh it is a non cross flow head, 77-78 model years only. Basicly the old chevy II
4 cylinder, bored out to use the same piston/rod assembly of the 301 V-8. Starting in 79 they changed the head to the crossflow style. And John Sawruk had to redesign almost every part of the engine to do it. Block, head, cam, ect... then the head design was alot closer to the 301's, but still not quite the same. It took be quite awile to find a replacement head for mine, it cracked shortly after I bought it, and now the timeing gear issue. I am done working on it!!!!
Mike
I for got to mention that the Air Pulse tubes in the pic's are from the original (cracked) California emissions head, only the CA & High Altitude cars got those funky looking tubes. The rebuilt 48 state head did not have provisions for them, so they are not on the car now. So it looks different without them.
But I do like the crome valve cover the 77's got!!!
We don't have as much time to work lately but Jory's still making progress
We found out awhile ago that there's no room for an air cleaner with the S10 intake so Jory made a hood scoop We went back and forth on what to do & since this is a budget build Jory offered to make something, surprise surprise. We decided on the Turbo TA hood scoop, flipped. I can't wait to see the finished product but it's lookin good so far
Come on Mom, lemme drive!! Last edited by dm_fan; 01-06-2010 at 03:18 PM. Reason: re-posting pics |
The next piece of the puzzle is the clutch hydraulics. I have to play show & tell on my clutch rod. It's off my Dad's old Sears riding tractor. I don't know what it was. I'm just happy Daddy doesn't throw things away
Cool Stacey . . . hope all else is well. I will see you sometime this week hopefully.
Steve |
I think one of the best combos for that car is the old Buick/Olds Aluminum 215 V8; it weighs slightly more then the original aluminum 4 cylinder , so it wont create handling issues. You can even use a Land rover engine; a Buford 350 HEI distributor drops right in. With a 215 & 5 speed combo you can get close to 30 mpg and they can pull 0-60 in the 8 second zone. Try that with the old Iron Duke -
I am getting ready to begin working on my 79 Sunbird Safari. It is a solid car with little or no rust. I did find some real nice front fenders for it. The others were beat up. This car has a Buick even fire V6, a TH350 and a 10 bolt posi. This was the very last "Vega" looking wagon.
fasteddy |
#38
Fast . . . cool. Post some pics please (when you can).
Steve |
#39
455Grandville,
I did complete the head change last year, but then the timing gear broke on the cam, and as I am planning on putting in a 383 SBC I didn't feel like working on the 2.5 internals again, and spending $$$ on it. I do agree that the Buick 215 is a great engine for H-bodies!!! And just after I bought the sbc parts I had a chance to buy a used turbo ecoteck from a soltice. I probebly should have jumped on it, but I didn't have the $2500.00 when it poped up, And it did include everything needed including the 5 speed trans. fasteddy, I have one 79 Sunbird wagon grill from a parts car a few years ago, if you want it just pay shipping. the other grill was busted out. I run 75/76 Astre grills in my 78 Sunbird wagon. And don't have a use for the one year 79 grill. Are you planning on keeping the 3.8? I have done a few things to the 3.8 in my Wagon.
#40
keep up the great progress on the car...
i have to say..... it truly is bringing back some H-body memories... to think.... i ummmm am guilty for slaughtering about 14 of them.... i was young, broke, but what a learning curve it was for me and my friend.... we still talk about it to this day.. |
