#81
Hold on man, the differential is just the part the ring gear bolts to inside the entire axle housing, the differential is what holds the spider gears and Posi with have little clutches and a springs inside as well. You don't change the whole rearend itself. The axles, ring and pinion gears and the axle housing are reused. The differential assembly is the "internals" of the rearend so to speak. You just can't used the open differential (single -track) to make a "Posi" aka "Limited Slip" aka Safe-T- Track (Pontiac name)
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
#82
oh, okay, gotcha. alright, well that's great, that means i can have posi in all my cars once i have the time and money for unnecessary upgrades. i don't know how it'll happen in my wagon since the axle is about 3 feet past the rear bumper, and the car appears lower than my firebird, but at least the firebird will be relatively simple.
proud owner of a 71 Grand Prix and a 72 8-seater LeMans, currently in the body shop while I start the 467/4 speed build |
#83
Lots of different slang for different things.
Around here we call manual trans - strait drives. Upwards north they mostly call them - sticks. We call the differential - rear or rear end. Some call it - axle. Some call it - third member. The carrier gets called - chunk - hog head - gut. It goes on and on ... The rear/rear end is usually where the tailights bumper and license plate mount. The axle is a long strait shaft with a wheel on the end of it. The differential is the complete rear axle housing/drive unit assembly. The carrier is what contains the ring gear and spider gears, it also determines whether its single trac or dual trac. And pepsi is better than coke. |
#84
Pepsi better than Coke ...Pssssttttt... Dr Pepper is better than both !
Republic of Texas Differential= Carrier , can we talk about spools ,lockers and torsen differentials now? Don't forget the Gov-Bomb ! LOL
#85
To add my .02 to BVZ's diff info . . .
Pontiac calls the differential housing a "carrier and tubes assembly", Group # 5.387 in the MPC. The part that contains the axle and spider gears and to which the ring gear bolts is called a "differential case", Group # 5.510 in the MPC.
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
#86
Then you got "Unit" Pause E You Knit
#87
Uh . . . . . . . . . . . . . . . . yep!
#88
I just spit pepsi everywhere.
Pumpkin and basket are all i'm calling that part anymore. The part that the ring gear bolts to, that is. |
#89
Maybe you should look into gettin' that fixed, Todd!
#90
Nothing worse than a sticky keyboard...
Current Pontiacs - 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
#91
Lloyd .....
lol just let a young old man enjoy his soda in his own ways. TYVM |
#92
Okee-dokee . . .
#93
Lloyd - he meant "so-dee".... (as in "sodee pop").
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
#94
Can't stand either one . . . never had a taste for ANY carbonated beverages besides beer.
Unsweetened iced tea, water, COLD 1% milk, low-sodium V8 vegetable juice, Miller Lite, and cheap trailer-trash pink wine are my preferences, LOL!
#95
Another wandering thread.
#96
Guilty as charged . . .
My apologies to the OP!
#97
no problem, i'm laughing. i don't have anything to report until sunday or monday anyway, so it's all good.
#98
A 4-speed Sprint is a rare beast indeed, I have the exact numbers built at home (thanks to Fred Simmonds years ago) When I bought my 69Sprint it had a Correct Saginaw 4-speed installed in it, but after running the numbers we found out the car was an original 3-speed car.
But if I remember correctly they made less then 400 4-speed Sprints in 69. But being a 69 manual sprint would be the 230 HP version of the OHC-6. With the hotter H cam, and the odd valve angles, and a couple other small chages, carb ect. The standard rear gear will be a 8.2" with 355 gears. And as previously stated A/C was not available with the sprint option in 68 or 69. You could get A/C on a standard 1 bbl OHC-6. Good Luck with the car. When ou get it if you need any parts check with me I may have them.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
#99
But remember
Rare does not equate to valuable every time. Be careful not to put $40,000 into a car that will be worth $15,000 when you are done. It is not hard to do.
#100
well, as i've said, i'm not trying to buy and restore the car to resell it. but on that note, that is the main reason why i am planning on doing everything on it(as well as my other 2 cars) myself, with the exception of paint, and possibly stripping the body down to bare steel. i might have the shop do the stripping just to make it easier on me. and unfortunately, i'll probably have to have a shop repair my '72's endura nose and fiberglass hood. i might attempt those myself, but i'm still on the fence about that.
