Formula Wheel Question
Forgive me is this has been covered. Can I run a formula wheel on a 77 non-tilt column without any issues? Of course, all the correct hub/horn items that are for the wheel. Will I have any space issues because of the non- tilt?
I would think it would work. I put a formula wheel on my 1986 Grand Prix, when I had it, and it looked factory. I see formula wheels on other Pontiacs all the time.
Also, my 1976 Plain Jane Firebird has a formula wheel that the previous owner installed. It looks like it came that way.
You will be fine.
My 72 Firebird with non tilt has one on it and it works fine
X10 it was just another wheel option, column doesn't affect it.
Whatever you decide, please think twice about using the repro Formula wheel commonly available. They bend if you look at them cross-eyed, and some have broken. The only aftermarket Formula style wheel that you should consider is the LeCarra. Caveat is that the rim is not molded like OE. It is stitched leather.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Thanks for all you input. I will proceed with the Formula wheel add.
I second what CanAm said. The reproduction ones are junk.
The Following User Says Thank You to 1965gp For This Useful Post: | ||
Did you need a diagram showing the extra parts needed for wheel swap?
