![]() Quote:
Secondly, sorry the carb coloring doesn't meet your standards. Next time I'll check with you first and make sure it's OK with you. The carb was original coloring and only sonic cleaned. The remaining color was just fair and I airbrushed some carb tone on it. The flash really makes it look strongly colored. Perhaps you can provide some photography tips also, so that the color appears more close to natural and meets your approval. I have no interest in your Holley tips but feel free to stroke your own ego if it makes you happy.
Triple Black 1971 GTO that runs just fine without Tom V's advice. |
.................................................. .................................................. ..................... .................................................. .................................................. ..................... Basically that is what Post #21 said. Have a good evening and I hope you get your Holley Carb issues resolved. Tom V.
Somebody fixid it, nice now.
Carbking Jon's 2-56 & Brass Hex stock make good sense to me for times-of-need! Tom ; i seem to like the posted holley color variation. if my 1970 1050 had that i'd be okay with that. |
![]() Quote:
![]() Quote:
I don't have a Holley Carb issue, I have a carburetor install challenge due to some engineer's oversight, probably a like-minded friend of yours.
I understand completely. My shop has been in the mid 90's lately. I have a couple of outstanding fans that make it tolerable.
![]() Quote:
If one uses the correct length studs and correct nuts this is all a non-issue. However I understand the OP not having access to the above which would create a bit of a frustrating situation. |
The correct parts were designed to make this installation a breeze. You didn't have them. It's something that comes along with buying used/second hand parts or reading the directions after the fact (usually what I do) ..... I get your frustration though.
I work in the heat a lot. Not a problem. Cold bothers me more.
I'm the same way.... Can't tolerate much below 60 degrees anymore.
Me too when I ran a similar combo.
Just an FYI. I also tried the short "jam nuts" Easier to initially thread on but impossible to get a wrench on to tighten. Not enough shoulder on the nut to grab at an angle like you have to with accelerator pump arms and plungers in the way.
Perfect. Have a great day.
Thread Tools | |
Display Modes | |
