#41
Hard to argue with that.
On the RAIV engine, that back intake manifold bolt is just a bolt. I suppose I could change it out to one with threads on top and then use a nut to attach the plug wire holder. The intake bolts themselves are too big to fit into the plug wire holder hole. |
#42
Thanks very much for the offer. With my new drivetrain, I won't be able to run one. Also, at least for the time being, I prefer manifold vacuum.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
#43
As far as I can tell that's what was done from the factory too. This was taken last September, on the engine that started this thread, before I pulled anything.
#44
Would you happen to have a pic of the left hand rear wire loom and bolt? It looks like that loom bolts into the corresponding head bolt hole and I assume it uses a bolt similar to what holds the TCS switch on the right hand head?
#45
if no one else chimes in, I can absolutely get you a picture, but it might be next week before I can get to it.
#46
#47
That’s great. Thank you! Can you tell if the bolt seems to have a shoulder on it?
#48
from what I have seen (I believe that hardware varied with the plant, and date depending on availablity) they do not have shoulders.
#49
I’m not so much of a purist that I won’t put in a few deviations from stock. Replacing the crappy cost-saving ‘71 plastic wire holders with the super deluxe ‘70 wire holders is one of them!
The Following User Says Thank You to giles For This Useful Post: | ||
#50
Sorry for the late reply, I've been out of town. No shoulders on my bolts. I can get more photos if you want.
Thread Tools | |
Display Modes | |
