SOLD Pontiacs The cars in here have already been sold. The topics will be kept for a few months for referance. |
Moving in a different direction, too many project right now
$17,000 obo Engine: Block 75 YF 400 Stroked Kit Stroked crank, rods, and pistons, pins, and Bearings Oil Pump 80 psi heavy duty oil pump formance Heads Kauffman 85cc D-Port Aluminum Heads (flow 310cfm) Lifters Comp Cams Hydraulic Roller lifters Cam Schneider Racing Cams Hydraulic Roller -278-86RH Rocker Arms 1:55 Roller Rockers Timing Set JP Roll master Push Rods Comp Cams Premium Chromoly Intake Manifold Offenhauser 360 deg dual quad Modified to flow 290 cfm Carburetors(s) 2x4 Edelblock Carter AFB's Distributor Mallory Unilite Gasket Kit Felpro Engine rebuild gasket kit Starter Gear Reduction ROBB MC Headers 4 into 1 Dougs Fuel Lines Earls dual quad fuel lines Linkage Earls dual quad progressive linkage Carburetor Spacers Adapter plates for intake to AFB Radiator Aluminum 2 core Radiator Engine Machine Work Prep block for 461ci stroker kit 3.00' mains with 4.25' stroke D’Macs Automotive Engine Assembly Assemble and perform engine break in D’Macs Automotive Air Cleaners SD reproduction air cleaners Rear Main Seal BOP Viton rear main seal Alternator OEM style single wire Valve Covers Custom Fab Alternator bracket SD reproduction bracket Flex plate TCI Street Strip R&B Total Performance Transmission/Rear-end: Transmission 86 BOP GNX 2004r ProTrans Rear End GM 10.2 4pin 4.33 Posi GM axles BOP 28 spline Transmission Rebuild Street/Strip rebuild Stall ConverterNon Lockup 3500 Stall Continental unit Auto Trans Shifter B&M Pro Ratchet Summit Racing Electrical : Electric fuel pump Holly Black fuel pump Electric fuel pump relay Battery Optima Red Top battery Battery tray Battery relocation kit Line Lock Tachometer Auto Meter Volt Meter Gauge Auto Meter Oil Pressure gauge Auto Meter ng Water Temp gauge Auto Meter cing Transmission Cooler B&M Cooling Fan Relay Painless Wiring Chassis: Trans Crossmember Fabricated Rear Brakes Stainless Steel Brakes GM disc brake conversion kit Master Cylinder GM dual 4 W/disc Front Brake brackets Stock GM disc front wheels 15x7 - front Cragar SS wheels for disc brakes Front tires 670x15 Bias tire reproductions Rear Wheels15x8 – rear Cragar wheels for disc brakes Rear tires (slicks) 15x27x9.0 M/T Drag Radials Misc. Braided lines Body and Interior: Seat Fabric Original fabrics SMS Auto Fabrics Seat re-cover Beach Auto Interiors Paint and misc: Paint and Body Body work and paint Steele Rubber Trunk Seal New Steele Rubber Door seals - coupe New Steele Rubber Cowl seal New Steele Rubber Door vent window seals New Steele Rubber Door and hood bumpers New Steele Rubber
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." --Thomas Jefferson, letter to William Ludlow, 1824 |
SOLD
