I can;t tell you the difference but the tank and vent on my 81 smells of gas-identical setup on my 78 does not. I hooked a factory charcoal setup on the 81 and it was fixes. And yes the vent line is the source not the carb.
Where the stock one was, front right behind the headlights.
I am very much considering one in the trunk behind the rear seat. Running a couple bulkhead fittings through the trunk floor
That’s where I put mine.
