Old 10-04-2022, 08:22 PM
indiangiver 68's Avatar
indiangiver 68 indiangiver 68 is offline
Default Running gtslow at the track
Thought I would have a little fun tonight. Brought my stockish 68 400 4 speed 3:55 open rear car to great lakes dragaway. First run was better than I thought. 14.53 at 98.37. Can't launch at all just got to roll out. Next year posi and drag radials might be able to crack into the 13's.
The Following 3 Users Say Thank You to indiangiver 68 For This Useful Post:
Old 10-04-2022, 08:24 PM
A picture
Old 10-04-2022, 08:36 PM
Another picture
Old 10-04-2022, 09:07 PM
indymanjoe's Avatar
I have some of the same slips lol nice car!
looks like 14's as well tire size.
Old 10-04-2022, 10:23 PM
Great looking car and respectable times! If you know the elevation, humidity, air pressure and temperature, you can calculate the corrected time and MPH
http://www.dragtimes.com/da-density-...calculator.php
Old 10-05-2022, 09:26 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Beautiful car! Get that 60' down and you're there in the 13s.
Chris D
Old 10-05-2022, 04:27 PM
Just about impossible to launch on 355 gear open rear. Just came off idle and eased into it. I have a posi to install. I will update next year. Was fun to run it and get a base line.
Old 10-05-2022, 11:36 PM
Mcronk Mcronk is offline
Traction is what is holding you back. The mph should easily run mid 13s. I did so with my 67 GTO running in the NMCA Stock ET class back in 95. It ran 13.60s to 13.50s at 98 mph. I had the suspension set up so that the car would almost lift a wheel off the ground. I was sponsored by BFG and ran their drag radials. Some basic suspension mods and tricks allowed the car to hook very hard. I actually broke a ring gear spacer, side gear, and split a non posi case with a mini spool in it. Engine was basically a stock 400 HO. It was all in the gearing, convertor, tuning, and suspension. Car was heavy and weighed 3,960 with me in it race ready. I won the class that year with it!
ID:	600019   Click image for larger version
ID:	600020   Click image for larger version
Name:	TA NMCA Winner sharpened.jpg
Old 10-07-2022, 12:20 PM
That’s impressive Mark!
Funny how the article cited your ‘67 as a ‘68. Reminds me of that Seinfeld episode where George exclaims his dad bought a ‘68 GTO and a ‘67 shows up in the scene.
I ran my stock ‘69 last summer and ended up in the high-14s. Started a thread on it: https://forums.maxperformanceinc.com...d.php?t=853526
The Following User Says Thank You to will slow gto For This Useful Post:
