Old 09-01-2022, 12:33 AM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Default 350 Vortec rebuild -- cracked block
I recently purchased a 1999 Malibu Sportster LX ski boat with a cracked block (900 hours on engine). I ran the engine briefly. No knocks. There is a crack in the lifter valley and the engine is a "gen 3" vortec 5.7 95-99.
I'm trying to determine how much of the current engine I can re-use and what machine work I will need done. I'm assuming the used block will need to go .030 so maybe some new pistons? Valve job? What about reusing the cam, main and rod bearings, stuff like that? I'm trying not to get too far down the rabbit hole on this one.
Also, how big of a deal is a 4 bolt main vs a 2 bolt? Most of the "880" blocks I've been finding are 2 bolt. Any advice is appreciated.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 09-03-2022, 03:08 PM
mgarblik mgarblik is offline
Went through a similar situation with a friend's boat last year. He bought a 19Ft. early 90's open bow with a 4.3. Got is cheap. Owner said it had a cracked-transom, which it did. He "forgot" to mention the engine had froze over the winter and was cracked everywhere. It ran fine, but water leaking out of every pore when it warmed just a little. We had a hell of a time finding a decent core. Marine cores were VERY expensive. Ended up buying an engine from as Astro Van with pretty high mileage but clean. Changed out all the parts, and new gaskets. Put it in the boat. Ran very quiet and thought we were done. After about 10 hours of time on the water, out of nowhere, it developed a lite rod knock that became a LOUD knock after about 15 minutes. Ended up doing a proper +.030 overhaul on the Astro engine. It's been fine for hundreds of hours now. My advice is to rebuild the new engine properly, using the rotating assembly and heads from the new engine. You can save some money by possibly using the marine heads over, but absolutely have them pressure tested. If the block froze and cracked, chances are very good the intake manifold, exhaust manifolds, crossovers, heads and anything that has water going through it is also cracked. Going to need to check all that stuff. Either magniflux or better yet pressure test. If you keep the RPM's reasonable and have the block line honed, a 2-bolt main 350 is probably fine. Both the 4.3's I spoke of were. If the marine cam is OK, I would reuse it in the new engine. Our marine cam was chewed up from engine failure and the engine was down on power a little with the Astro Van cam. Good luck with it.
