Old 09-01-2022, 06:00 PM
Mcronk Mcronk is offline
Default 68 GTO high pressure power steering hose
Looking for NOS or excellent original 68 GTO high pressure power steering hose. See picture. Thanks.
Old 09-02-2022, 08:57 AM
Andre's Avatar
Andre Andre is offline
I bought an inexpensive one online and it looks exactly like the original I took off my car which was surprising.... unless the one on my car was not original?
Old 09-02-2022, 09:25 AM
The one on the car has been replaced (yellow lettering on the hose) and has a much different bend where it goes into the steering box. So far the ones I have seen online are like the one I have or are a two piece hose with a crimp band in the middle of the hose. Where did you get yours?
Old 09-02-2022, 03:09 PM
Scott Thelander's Avatar
I should have a real nice original 67-8 hose
off a low mile tempest I parted years ago
if your looking for a born with look
does not look nos but its a nice orignal
if interested,,,, not here for pics but I can when I go down there ,,,,
Old 09-02-2022, 03:22 PM
Scott,
Please send a picture when you can. At this point I have not found anything yet. It will be going on this car.
Old 09-09-2022, 06:22 PM
Default Ps hose
Pictures
ID:	598175   Click image for larger version
ID:	598176   Click image for larger version
ID:	598177   Click image for larger version
ID:	598178   Click image for larger version
Old 09-10-2022, 09:28 PM
Interesting assortment. The ones where the hard line loops back towards the steering box appear to be replacements that were used when the original style was no longer available. My original 72 SJ GP has that style hose. The one with the tag that says "real 69" I believe is the original design and what I am looking for. Can you get a couple of close up shots of the one that has the tag on it showing condition of the rubber, threads, hard lines? Thanks.
Mark
Old 09-11-2022, 01:17 AM
dataway's Avatar
dataway dataway is offline
Just as a point of information ... I was able to re-zinc plate the metal portions of my original hose which made it look much nicer.
A possible option if you find on that is very sound, but not very attractive.
Old 09-11-2022, 01:21 PM
Did you send it to someone for zinc plating or do it yourself? Very interested in how to do this. Thanks.
Mark
The Following User Says Thank You to Mcronk For This Useful Post:
Old 09-11-2022, 03:37 PM
Default Power steering hose
More pics
It’s nice! A little surface oxidation on the one fitting other is sweet
Corners on nuts excellent
ID:	598330   Click image for larger version
ID:	598331   Click image for larger version
ID:	598332   Click image for larger version
ID:	598333   Click image for larger version
Old 09-11-2022, 08:21 PM
Looks good. PM me how much you want for it.
Thanks.!
Old 09-11-2022, 09:26 PM
Pm sent
Old 09-12-2022, 01:47 AM
dataway's Avatar
Looks like you already have a hose ... but the zinc plating does come in handy for other hard to find parts. I did it myself using basic zinc plating techniques, but just immersed the metal end of the hose. Easiest way for a person new to the process is probably buying a kit from Caswell, Eastwood etc. Pretty easy and quick, no real nasty chemicals like some other plating processes.
There is a pretty big thread on it in the Members helping Members section called "Zinc Plating Fun"
Old 09-12-2022, 07:51 PM
Thanks!
