67 tempest under dash. Wire harness
Hi everybody. Looking for a used wire harness under dash fuse box area. Mine is smoked. Used needing repair is just fine. Let me know what you got. Thank you!! 67 tempest.
I may have one from a '67 GTO that I parted. What is the 4-digit "code" on the fuse block? Thanks, Bob.
IMHO I would avoid a 50+-year-old wiring harness regardless of outward appearance.
M&H has what you need in all correct factory wire color coding, Connectors, etc. Plug & Play easy installation. Yes, they are pricey. But Pay Now or Pay Later with an old hardness. JM2C Cheers.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
