Old 03-10-2022, 09:40 PM
Mark O'Neal Mark O'Neal is offline
Default 1956 287ci
I have a buddy searching for a 3.250 stroke crankshaft, if anyone has been hiding one from human eyes for 50 years or so.
Any help in locating one (or three) would be appreciated.
If there is a better place to put this, please let me know.
Old 03-10-2022, 10:04 PM
tom s tom s is offline
try these guys.Tom
https://www.pontiacparts.net/
Old 03-10-2022, 11:09 PM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
Noticed your title "1956 287".
There weren't very many 1956 287 cubic inch engines. More likely that your friend has a a 1955 287 cubic inch engine or a 1956 317 cubic inch engine. Whichever, he needs to be sure before looking for a crankshaft because the Master Parts Catalog says the 1955 engine uses crankshaft part number 518047 and the 1956 engine uses part number 521602.
No, I don't know the difference.
Old 03-10-2022, 11:16 PM
Thank you.
They don't appear to have any engine parts.
Old 03-10-2022, 11:17 PM
Neither do I...but as long as it's 3.250....we'll make it work. We have to make spacers anyway.
Old 03-10-2022, 11:27 PM
I bought a 57 crank from them.Call and ask.Tom
Old 03-10-2022, 11:28 PM
Thread copied to Big Pontiac Parts Wanted classified forum.
Old 03-11-2022, 12:30 AM
Sirrotica's Avatar
FWIW, both the 1955 287 engine, and the 1956 317 both list a 3.25 stroke. The difference is in bore size, stroke was the same for both years. I have no idea if the main, and rod journals are the same size.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-11-2022, 12:46 AM
They are 2.5 mains.I used those main bearing in my 303 SCCA RA V engines.57-58 got bigger and 59 went to 3in.Tom
Old 03-11-2022, 01:02 AM
‘55 - ‘56 = 2.5”
‘57 - ‘58 = 2.625”
‘59 - up = 3”
Old 03-11-2022, 10:55 AM
FYI,most of the early cranks were forged but not all!Tom
Old 03-11-2022, 03:29 PM
Doesn't have a crank, but does have a short block. That may work out too.
Thanks.
Old 05-02-2022, 04:14 PM
d2_willys's Avatar
d2_willys d2_willys is offline
The difference is probably the pilot bore for the dual range hydramatic pilot shaft. Stratoflights do not require a pilot bearing.
Old 05-02-2022, 04:59 PM
but some '56 Pontiacs had dual-range Hydra-Matics.
Old 05-03-2022, 12:15 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
I can't prove it, but I believe that all '56 and '58 cranks were forgings; all other early cranks were castings.
Old 05-03-2022, 07:36 PM
694.1 694.1 is offline
PM sent
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 05-03-2022, 08:20 PM
Jack,I can tell you forsure they are NOT!I bought one myself and had to take it back where I bought it.Also the one Kaase got was cast.They were both 57-58,dont know about 55-56.Tom
Old 05-03-2022, 08:48 PM
Burgess's Avatar
Burgess Burgess is offline
I can confirm that a 518047 is forged, and has a counterbored pilot hole.
Old 06-25-2022, 01:50 PM
flat-bill flat-bill is offline
Default '56 motor parts
Are you still looking for a '56 crank? I have one that is probably std/std. Maybe some other stuff too. Send PM. Billk
