Old 06-29-2022, 09:22 PM
Pmrockhead Pmrockhead is offline
Default 64 Catalina loose manual antenna
Just bought a 64 Catalina 2 door and the manual antenna accessible inside the passenger door hinge area, is loose. The antenna rotates and leans from side to side. How do you tighten it? There seems to be some type of scissor nut or something under the antenna up against the fender that is not obvious how to tighten
Old 06-29-2022, 10:39 PM
That sound like an aftermarket antenna. You should be able to Hold the antenna shaft and turn the body of the base to tighten.
