Old 05-30-2023, 04:11 PM
jhein's Avatar
jhein jhein is offline
Default Carb vacuum nipple
When I was troubleshooting my Qjet recently, when I removed the vacuum line for the choke pull off, the hose was very tight and pulled the nipple out of the carb body. I plugged it back in and it feels snug and it operates the pull off. Should I use something like locktight on it or just leave it?
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 05-30-2023, 06:01 PM
I have had that take place on me and I forget what size I used, but I tapped in a long taper center punch to flare the tube out I bit and then drove it back in the carb with a wood block.
I also think I may have used whatever size drill bit to put a slight chamfer on the carb body to help get that flared out end started.
Old 05-30-2023, 06:21 PM
gtobird's Avatar
gtobird gtobird is offline
Well, when you remove the various tubes from the airhorn (inside the quadrajet), it's common practice to put them back in using red loctite. In fact, did that last week. The point being, I don't see how this would be any different. Just make sure to keep it only on the outside of the tube before knocking it back in.
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
The Following User Says Thank You to gtobird For This Useful Post:
Old 05-30-2023, 06:29 PM
Yep, happens occasionally. Like said, put a little loctite on it, put it back in and forget about it. It'll be fine.
https://youtu.be/XqEydRRRwqE
Old 05-30-2023, 07:00 PM
Schurkey Schurkey is offline
Yep. Whether it's an existing nipple that pulled out, or a modification to add a nipple where there wasn't one before, a dab of threadlocker on the tubing works wonders.
Old 05-30-2023, 08:37 PM
jhein's Avatar
Thanks gents
Old 05-31-2023, 08:12 AM
Mr Anonymous's Avatar
Nipple <snicker.....>
heheheheheheeeee
Clutch Guys Matter
53 Studebaker, 400P/th400/9"
64 F-85
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 06-03-2023, 02:41 PM
tjs72lemans tjs72lemans is offline
Yup, nothing wrong with a little lube on the nipple!!
