#81
Also Tom, what is your opinion on a safe timing for 16-18 psi with the 110 octane? I know you cant give me an exact number, but I'm just looking for a ball park estimate that this combination would be safe with. It will be a blow-through EFI TBI setup(Fitech 1200 PA) Non-Intercooled at this point.
1978 Trans Am Pump Gas 461 Stroker |
#82
I tell people like Charlie66 to stay under 27 degrees of total timing.
He has never hurt anything with that suggestion due to combustion issues. But he took baby steps to get there. I would start out at 22 degrees and learn how to read plugs as well as having a a good Air/fuel meter system initially. Just because you are at lower boost DOES NOT mean that the timing is wrong. Make the power with boost, not timing. Stay below 27 degrees and you will have an engine that will live a long time and when you turn the boost up it will continue to live. A bad decision in timing has hurt more boosted engines than any basic failure of parts. Tom V.
#83
#84
JMO , If i was not using a cooler ( which i would never do) i would be REAL conservative with the timing...
My Half AN Injun..... |
#85
The air is so hot coming from the turbo, even at low boost levels, that 10-12 psi could be 150 degrees hotter combustion charge temp vs ambient temp easily. 230 degrees with no cooler is a very hot charge temperature and really promotes combustion issues.
That is why some like 70 Bird install a Snow Water Injection system before the throttle body or carb. You want to be in the 120 - 140 charge temp range, not 250+ range. Tom V.
#86
Hmmmm... I appreciate the help and guidance... I may want to look into a water/meth injection system then. Might even be able to stick with my 9-1 compression with the water injection from what I'm reading? It really sounds like a great thing to do to be on the safe side, and a potential significant increase in power.
#87
I just got off the phone with dad, and I had forgotten about a Treadstone Air-Air Intercooler that he had left over from his D1SC Procharger car, it is like brand new, so maybe I will just use it instead of the water injection, since I already have access to it. Here are sone features of it...
TRV25 Series Intercooler 1000HP Tweet Treadstone Intercooler features superb quality highly efficient bar and plate construction. These intercoolers are perfect for any car making some serious horsepower; Supras, Mustangs, Nissans, Grand Nationals...etc. This intercooler is 3.50" thick, and will easily support 1492 CFM's 1000HP at max efficiency 1.5psi pressure drop. 1-Year Warranty. Intercooler will come with no logo, "Treadstone" logo can be requested in Blue, Black, or Red. Overall Size 26.50" X 12.00" X 3.50" Core Size 25.00" X 6.00" X 3.50" 3.00" Inlet/Outlet 1000 Hp efficient Mounting tabs for easy installation
#88
In regards to timing, theres also a cliff that you want to stay away from on the low side as well. Maybe you knew this already but i just figured id throw it out there just in case . I have a good story on that one . Thank god i learned from a friend and not and not on my own turbo..
#89
Thats the exact cooler i have.
#90
Thats awesome! How do you like this cooler? Do you just run the cooler, or do you run water injection along with it? What IAT are you seeing with it? I appreciate the help
#91
Well every engine will differ. Its just a matter of knowing your air temps in your manifold not your intercooler pipes, AFR and most importantly reading your plugs. If all those are in check then you can play with your timing to see what gains you can get . Its not always what your buddy or what you read on line will be for you. You have to find what your combo wants with the giuld lines of what your being told will work.. And its not only burning your pistons that low timing can do. Low timing can burn the tips of your turbin wheel fins right off. Basically ruin your turbo ..
As for my cooler, its good , but anything over 1100 hp id be looking for a better one.. My temps vary with the weather. In warm weather its always operating at the ambient temperature. So if its 80 degrees out thats what i have at idle in the manifold. It will rise from there as i make a run. But if theres more boost involved then at the end of a pass it will be higher. So say i make a run and it 80 degrees out with 28psi ( thats my everyday setting ) by the end of the run the temp with be like 140 . But if i had 34 psi ( my second setting i use ) I ll have 156 - 160 ish.. I use E85 just so you know.. and no , i dont use water injection. I thought about trying it but never got around to it. Always something that happens that needs fixing that keeps me from trying it. High boost is high maintenance . My high setting right now is 44 psi.. If this deal im looking to get comes though ill be stepping up to 50 psi ..
#92
#93
Tom V.
#94
#95
A friend of mine did it.. Burnt about 3/8" off all of them .. But he was only running 10 degrees .. He was scared. Look where that got him . lol Hes at 18 degrees now . It wasnt a Pontiac ...
#96
One thing i might add is , When i was at the dyno with my friend ( chassis dyno) he gained 100hp adding 8 degrees . He was at 10 degrees from start and 18 degrees when done . Anything after that was minimal . Think he went to 23 dgrees and made 10 more hp . At that point the motor was done so he backed to 18 to be safe.. So thats why going to the edge IMO is not woth it..
#97
Don't ever say to a dyno operator, "can you give me a few more HP from where we are".
When you say that you take the liability off of him and it is all on you. Now if he kills a head gasket or torches a piston/valve, it is on you to fix it. Lots of good Dyno Guys out there, Ken Duttweiler being one of the best in the game, and I never saw a more conservative Dyno Guy. He knows how to make them live for 5 miles on a Bonneville Salt Flats run and still take the record for the fastest 4 wheel vehicle (not a Jet) that ever ran on the salt. We are talking 460+ mph runs. Timing is dangerous because many do not understand how destructive it can be with too little or too much timing for a given engine. Also manually VERIFY that the harmonic Balancer is accurate as far as your timing assumptions. Tom V.
#98
Plus may I add there is NO SUBSTITUTE for reading the plugs. When it comes to timing (or fuel) don't trust anything but the plugs. The motor will tell you what makes it happy. Makes small changes at a time and pay attention. Just my 2 cents
6.98 @ 199mph 4.53 @ 164mph |
#99
#100
Water to air intercooler intake air temp datalog for ~19lb boost.
2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
