Old 03-28-2024, 09:37 PM
grandam1979 grandam1979 is online now
Default 1964 GTO dash gauge ground?
Does anyone have a picture of the ground straps for a 64 dash? Thanks
Old 03-28-2024, 10:56 PM
Peter Serio's Avatar
Default The ground wire for the dash cluster= both 64 and 65 Lemans & GTO.
On 64 or 65 there is no actual ground strap that I can remember, for the gauges ground there is just one thin black wire that is partway tape wrapped into the main dash harness.
One end of that wire slides onto an un-insulated tab that is spot welded into the side of the metal socket that holds the light-bulb for your headlamp high beams on bright red indicator light. (The power + wire that lights up that indicator light-bulb is lime green color.) The other end of the ground wire exits out of the tape wrapping behind the dash bezel and above the clutch and/or brake pedal support. Here is the only drawing I have that shows the ring end attached. You have one sheet metal self tapper screw + a star washer to hold the "ring" end of the ground wire to the side of the pedal support underneath the dash.
Name:	64-65 GTO gauges Ground wire~revs.jpg
Peter Serio
Owner, Precision Pontiac
Old 03-29-2024, 07:30 AM
Thank you very much that definitely helps.
Old 03-29-2024, 12:14 PM
Default 64 65 GTO dash cluster ground wire:
Here is the other end of the black wire, (The push-on end).
Name:	64-65 GTO gauges Ground wire~revs+.jpg
Peter Serio
The Following User Says Thank You to Peter Serio For This Useful Post:
