1973 and 77 motor mounts the same?
On 1973 and 1977 A-body Pontiac LeMans, etc.; are the 400 Pontiac engine motor mounts, stands, etc. the same?
Sorry but no, 64-74 A-bodies use the same type,
https://secure.amesperf.com/qilan/Search_Web 75-77 use What I always called the "Captured " Style. http://www.autopartswarehouse.com/de...QWSEM2292.html
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
What Jeff said. By '77 they used the "triangulated" style mount that was used on the F-body since '70, where the 3 bolts holding it to the block were in a "triangle" and the frame side of the mount was a "clamshell".
Pontiac Motor Mount Hole ID
Thanks for the replies and info. I found this concise Pontiac engine block motor mount information from Wild About Cars Online and wanted to share it. Join for access to the full library here: http://www.wildaboutcarsonline.com Quote:
http://wildaboutcarsonline.com/cgi-b...=9990390327777 |
The 3 holes that aren't pointed to by the red arrows, are the ones that were added for the 70 Firebirds.
The later years block that only had 3 holes used the ones not pointed to by the red arrows. (basically the older 2 bolt mount holes went away)
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." Socrates |
Text is incorrect pertaining to blue and green arrows.
K. What IS the correct text for blue and green arrows? Thxs
3 mount holes
Props for your clarification Brian. To be clear: You are referring to the 3 holes circled in beige in the revised photo (below), yes? Thanks. Last edited by Alvin; 10-18-2011 at 05:56 PM. |
That's right...the 3-holes with the "squares" around them are for the '70-up F-body. I don't know when the change-over started from the 2-bolt mounts on non-F bodies to the 3-bolt arrangement, but the consensus is 1975, and by 1977 all blocks had only 3-holes regardless of what body they were going in (my Can Am for instance has a 3-bolt mount block and shares the same type mount as the F-body).
In 1975 all the mounts became 'clamshell' type, which used the 3 bolt mounting.
I imagine Pontiac did this for instances where service replacement blocks would still fit in earlier models with the 2-bolt mount...but might be interesting to find if there were any non-F body cars produced in '75 still using the old 2-bolt mount...never say never.
Probably the big car engines went to 3 hole. I think when Pontiac started to drop the 400 production all the engines went to 3 holes.
Did you mean when they dropped the 455 production?
