TH400 Crossmember for 78 Trans Am
Many many years ago and the day before Pinks All Out, Greg Merrick and I were replacing the TH350 in my car with a TH400 Greg built for Steve Hodge. Long story short, I had to make due with the TH350 crossmember as I flipped it around and redrilled the frame rails to make it work.
I recently ordered a TH400 crossmember for a 72 Camaro and was going to install it today. It looks just the same as the backwards TH350 crossmember. Am I missing something? Are the mounting holes on the frame different for each tranny or do I have the wrong mount?
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
The 70-74's had a different front sub frame, last time I checked it wouldn't work.
72 will probably not fit the frame rails I think earlier second gens are narrower. TH400 mounting pad should be about 6" further back. G Force/Summit make one 7lbs heavier than the factory crossmember. Also can cut the tab off a TH 350 for a 78 and weld it on the opposite side. I made a wooden jig to do that on the one for my 79 Camaro/IA2 project.
The '70-74 crossmember is slightly narrower and its an absolute RiG is to oblong the holes and angle the bolts slightly. performed that 3 decades ago in my '80 T/A, & the crossmember wasn't bolted in that good. A much cleaner job is as Skip mentions, take the '75-81 F crossmember, lop the tab off it & weld it to the opposite side. Have ran across that performed several times in late '70's F bodys that I was installing built up rearends in.
Some Caddies (I think the Seville models) came w/ a TH400 in them through the late 70's. They used the same subframe (from what I've read through old Hot Rod tech articles) as the F-cars, so it'll be a bolt-in, if you can find one.
Otherwise, mod a TH350 (make sure to offset the mounting tab to the proper side), or order s Summit unit.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
That is nice Skip. Maybe we should send you our crossmembers! I did use the G-force unit as you might recall in my 75 Formula when swapping the TH-350 to the 400 and failing to get the cross member change to work out correctly. But your setup makes it look repeatable and proven. Maybe you should make some measurements and a plan for that.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
Some pictures of the jig and crossmember ready for welding. The TH 350 mount as well as the BowTie Overdrives both have the mount slightly angle up towards the front so I kept the same angle.
That looks real good Skip
I also used the G force on the jig besides the Bow Tie. It is about 7lbs heavier than the factory(feels heavier than that). It does have nice arcs for the exhaust I think the Bow Tie does not-it is more straight. The G force also is almost level at the tranny mounting pad vs angled like the factory and Bow Tie are.
Plan is to use the welded factory on the TH400 going in the Camaro/IA and probably the G force for the 200R I'm planning for the 78 TA since 200R and TH400 are about the same. Maybe use the jig to weld on a plate to raise a section on the BowTie for exhaust clearance.
i think american power train makes a universal setup
and places like hurstdriveline have various x-members (gforce too) there is a subframe difference the universal kit i received from APT was for first gens i think it fits early second too, not sure last year i tried again, and they sent me 3 claiming they would work, they did not hurstdriveline one fit right in (i wanted the two bolt trans mount in place of the single one i had been using) |
Johnny406
So what is Greg merrick up to now? He bulit a engine back in 1999. |
