Old 07-29-2021, 07:42 PM
jokerstime jokerstime is offline
Default Control arm bolt hits the frame.
Hello, I was taking out the front, left, lower, control arm bolt to remove the control arm. The bolt head was towards the rear of the car. After taking the nut off and pulling the bolt back it hit the frame. lol. There was no way to get the bolt out , let alone put it back in. I had to take my grinder and cut the bolt off. Has anyone ever had this problem. I guess going back in I can reverse the bolt. Never had this issue on any of my other headaches, I mean gto's.
Old 07-29-2021, 08:09 PM
ZeGermanHam's Avatar
Interesting. If someone installed the bolt in that orientation in the first place, there must have been room to get it out. But regardless, bolt head to the front of the car is the correct orientation.
1998 BMW 328is (track rat)
Old 07-29-2021, 10:48 PM
Yep, the first thing that popped into my head was frame damage.
Old 07-29-2021, 11:35 PM
My wife’s Chevelle was that way. I was able to get it out without cutting it, but I thought it was odd as well. Reinstalled in the reverse orientation.
-Jason
1969 Pontiac Firebird
Old 07-30-2021, 09:17 AM
78w72 78w72 is online now
if it went in... it has to be able to come out.
Old 07-30-2021, 10:01 AM
wbnapier wbnapier is offline
Same happened with my '65 GTO when I changed the bushings. I had to cut it out. I reversed the direction when I reinstalled.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
