Old 08-22-2021, 10:12 AM
67428HO 67428HO is offline
Default Dog dish caps
Hi, What's the best way to remove Dog Dish caps ,besides carefully,without screwing them or the rim up? Thanks!!
67428HO
Old 08-22-2021, 10:35 AM
Jeff Hamlin's Avatar
I've used the old school wheel cover hammer with no issues.
The trick is to hold it with steady pressure to control it from slipping.
A tape-covered large flat screwdriver is another go-to way.
ID:	571726   Click image for larger version
Name:	POVERTY-DOG DISH  (1).jpg
Old 08-22-2021, 10:46 AM
Thanks!
67428HO
Old 08-22-2021, 11:05 AM
ZeGermanHam's Avatar
I've also had good luck with panel/trim removal tools like this. As Jeff said, just apply steady pressure and use tape or a rag to protect painted surfaces as needed. Also, don't forget to place a towel on the ground, because the wheel cover will inevitably pop off and hit the ground causing scratches if you don't.
1998 BMW 328is (track rat)
Old 08-22-2021, 01:40 PM
Chris65LeMans's Avatar
I use a cap hammer just like the one Jeff posted. As Ze mentioned, I use a shop rag between the claw and the rim/cap to protest finishes.
Install it with your hands - hook the cover around 2 of the 3 knobs, then use your palms to force it over the third. Always remove the caps your self before taking it into a tire shop/service place. No guarantee they will be as careful as you will - and the caps will get out of round over time if they are mis-handled. (So I've been told.)
Old 08-22-2021, 02:23 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
I took an old screw driver heated it and bent it and put heat shrink over the end , that works on mine .
Old 08-22-2021, 02:54 PM
burd's Avatar
burd burd is offline
They sell them with a rubber sleeve on the end, that’s what I used. I sold the too a while ago.
Old 10-31-2021, 10:37 PM
imposter's Avatar
imposter imposter is offline
Default diamater
whats the diameter of these caps im looking ro have a set of steelies made
Old 11-01-2021, 12:01 AM
GTO JONES's Avatar
I just ordered mine from wheel vintinques,15-8's and 15-4's and they fit fine.
Old 11-01-2021, 05:51 AM
Arrow
ID:	576727   Click image for larger version
Old 12-11-2021, 08:46 PM
blueghoast's Avatar
I use a brake spoon.
GT
Old 12-11-2021, 10:11 PM
misterp266's Avatar
I got 15x7 wheel vintiques 37s and they do not clear my disk brake calipers.
This is on a ‘63 FS with Scarebird conversion.
Will probably go the custom made route at some point. ‘63 needs the clips for the dog dish caps so there are no aftermarket wheels available.
" Darksiders Rule "
Old 12-11-2021, 10:18 PM
GTO JONES's Avatar
I think I got the 62 series
Old 12-12-2021, 03:39 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
These are the way to go: https://forgeline.com/wheel/oe1
Forged aluminum in any offset/rim width/dia you want. Unfortunately, they're a bit spendy at $7k for a set.
Old 12-12-2021, 05:42 PM
Yeah, just a little bit spendy at $7k...
Yep, that's what I have on mine. WV 62 Series 15x7" with 4.25" backspacing. Fit great over my CPP front disc brake conversion with D52 calipers and no problems in the rear with the Cadillac Eldo disc brake conversion.
Old 12-27-2021, 02:20 AM
lust4speed's Avatar
I just use a really big screwdriver along with a wadded up towel against the edge of the rim. The damage spot is usually on the outer perimeter and the towel takes care of that. As mentioned above, best to just use your hand to set the last rim nub into the cap.
Mick Batson
