The urge to upgrade should be tempered by actual usage.
Factory or replacement "cast" pistons give your block LESS Wear than a Forged Piston , which is harder. There are other light , but non wear piston options like KB., PONTIAC built these engines to have their power within Their "driving RPM" Range. 99% of Pontiacs have LESS power at 5k rpm than at 4k, even built up engines. With today's oil, and filtering, and balancing, even a stock rebuild will run well and last a very long time .
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear https://youtube.com/shorts/gG15nb4FWeo?feature=share |
If the motivation for a rebuild is concern about potential problems with the old internals, I would leave it alone for sure--especially if it's not a leaker and no other issues. If you're considering it not only for peace of mind, but also because you want to feel more power, I'd stroke it.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
The Following User Says Thank You to Gator67 For This Useful Post: | ||
I'd also vote for you to leave it alone.
General note to anybody that is preserving a "correct" block in a car....especially a highly collectible like a numbers-matching SD. If cylinders need to be cleaned up, figure the minimum amount of metal removal to clean up and then get custom pistons and rings to match. It wastes good metal to go from stock to +.030", then to +.060". Also, if one cylinder is gouged and needs to be +.060", there's no need to take all of them to +.060". It costs a bit more but it's relatively simple these days to get the exact piston oversize and file-fit rings to preserve your collectible block. Likewise, if you sleeve one cylinder, it can be returned to stock size while the other (7) are +.030", for example. FWIW, Eric
The Following User Says Thank You to Elarson For This Useful Post: | ||
I too would vote for leaving it alone and continue enjoying it. Several posts about boring for sleeves. IMO, it would be much more cost effective and you would end up with a better engine taking that block to .070 over with custom pistons rather than trying to install 8 sleeves. Probably save around a grand in the process as well. To install 8 sleeves, bore them and finish hone and deck the block would be at least 2K around here. A set of custom pistons around $800.00 with pins and rings.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Hopefully this is not a ridiculous question, but, since the motor has only 1000 miles since the recent build and boring, would it need to be bored? Could it just be honed?
When is the last time you changed wheel studs and lug nuts on this car?
Chances are they've been cycled/re-torqued more times than your rod bolts. Rod bearing failure happens with any rod if you thrash on it hard enuff. Clay |
Longevity wasn't why went forged rods and pistons, it was the ability to have quality pistons and a higher compression. I run 10 to 1 and there is a power advantage.
72 Bird |
mine has 2,000 miles on the rebuild....the builder also rebuilt the trans and put a changed out the pegleg rear with a differential...i kept the same 3.08 gears though...he massaged the auto trans w/different shift points as well so it snaps when i'm getting into it... |
