SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 09-16-2021, 10:24 PM
7D9TA's Avatar
7D9TA 7D9TA is offline
Default 2nd Gen Round Port Turbo Headers
Built by Ron Watt at Tribal Tubes in 2012. I had them ceramic coated black by a local coating company.
Fit very well with only minor dent to clear my steering column and one minor dent to clear the frame. They performed flawlessly. Never had issue with header gaskets failing running 20 lbs boost and a guestimated 40 lbs of exhaust back pressure. These have 1 ¾ primary tubes and 2 ¼ V-band collectors. The pictures on the motor were sent to me by Ron to show the headers in the test frame he used to build them.
$700 plus shipping from 78664.
ID:	573207   Click image for larger version
ID:	573208   Click image for larger version
ID:	573209   Click image for larger version
Name:	Pass side front straight on view.jpg
ID:	573210   Click image for larger version
Name:	driver side top view.jpg
79 TA
476, Single 88MM turbo
Street car. Pump gas, Radial tires, Full exhaust, 4000 LB race weight
Best 1/4
1.39 60 ft
9.03@149.55
Old 09-17-2021, 01:56 AM
R 70 Judge's Avatar
R 70 Judge R 70 Judge is online now
Are they stainless? Do you have any closer pictures of the welds?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 09-17-2021, 09:22 AM
7D9TA's Avatar
Mild Steel. I replaced the V-band with interlocking v-band and my welds are not pretty but they were effective.
ID:	573251   Click image for larger version
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 09-22-2021, 03:36 PM
7D9TA's Avatar
TTT
New Price. $600 plus shipping.
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 10-05-2021, 04:44 PM
7D9TA's Avatar
Bump
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 10-14-2021, 11:47 AM
7D9TA's Avatar
$550 plus shipping.
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 10-28-2021, 10:04 PM
7D9TA's Avatar
$400 plus shipping
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 11-04-2021, 10:15 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
What are the chances of these fitting a 1st Gen front stub? I’ll be building mine soon with Mustang Rack mounted ahead of the crossmember. I will be cutting most of the crossmember out and using 1-5/8” 4130 Tube and front plate.
Old 11-04-2021, 11:46 AM
7D9TA's Avatar
I do not know what the fit would be like. If you are modifying the subframe then you can make it fit the headers. My concern would be the front motor plate. You would probably need to allow the exhaust to go through the motor plate. A second gen frame has front steering and I had no clearance issues. I was going to change to a rack and had no concerns with the headers or exhaust interfering with the rack.
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 01-03-2022, 03:36 PM
7D9TA's Avatar
TTT $400
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 01-05-2022, 12:56 PM
7D9TA's Avatar
@Colin70TA, I got your PM. I tried to reply but get the message below.
"Colin70TA has exceeded their stored private messages quota and cannot accept further messages until they clear some space."
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 01-05-2022, 01:28 PM
racegto65's Avatar
racegto65 racegto65 is offline
Are these still available?
Old 01-05-2022, 07:37 PM
7D9TA's Avatar
I'm waiting on a reply from Colin70TA. If he passes then they will still be available.
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 01-10-2022, 04:55 PM
7D9TA's Avatar
These are still available. TTT
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 01-10-2022, 09:20 PM
Fast 69's Avatar
Fast 69 Fast 69 is offline
I’ll take them. PM sent
Old 01-12-2022, 10:19 AM
7D9TA's Avatar
** Sale Pending **
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
Old 01-13-2022, 09:49 PM
7D9TA's Avatar
**Sold** Thank you Fast 69 and thank you PY
79 TA
Best 1/4
1.39 60 ft
9.03@149.55
