Old 04-02-2024, 05:56 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
Pix2
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 04-02-2024, 06:02 PM
Ok just to nip it. I just looked at the pix i posted and they have a rust color. That is very misleading.
Old 04-02-2024, 06:06 PM
I think this might be a cam failure. Not a lifter failure. There is no roller flat spot. The roller never quit. Needle bearings seem ok
Old 04-02-2024, 06:24 PM
Maybe I should have named This Thread quote why did it fail because at this point I do not know
Old 04-02-2024, 06:40 PM
Like the roller and the cam lobe chewed each other up. Chicken or the egg
The Following User Says Thank You to jonmachota78 For This Useful Post:
Old 04-02-2024, 07:12 PM
steve25 steve25 is offline
Once the lobe got worn to the point of having enough of a groove the ware rate will sore!
The groove will grab at the sides of the lifter roller and then slow down its ration .
Old 04-02-2024, 09:40 PM
blueghoast's Avatar
Hmmmmmm
GT
The Following User Says Thank You to blueghoast For This Useful Post:
Old 04-03-2024, 06:13 AM
Formulajones's Avatar
Is it a cast iron core or billet?
https://youtu.be/XqEydRRRwqE
Old 04-03-2024, 06:50 AM
Is that push rod straight?
Was there not enough retainer to guide clearance?
Just grabbing at straws here since the only other reason to me would be the core was hardened uneven.
Old 04-03-2024, 07:50 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
Butt its been a great engine for 16 years and over 40k miles. Built in 2008 with the 274ex flat hyd and upgraded to hyd roller OF cam in 2012. Plenty of dragstrip runs, i can't complain.
It started making an unfamiliar noise, valve train frequency except not a hammering like a colapsed lifter, rather a scuffing/sqweeky noise. Removed the belts and looked for vacuum leaks to no avail. Put a tube in my ear and couldn't pin it down to one side or the other so figured its time to look at the cam. I kinda felt i was on borrowed time.
Jon
What about the lobe next to it in the first pic. Does that show any evidence of wear?
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
Old 04-03-2024, 09:26 AM
65 Lamnas's Avatar
65 Lamnas 65 Lamnas is offline
Well...that sucks. Sorry to learn of this.
Do you always use the same brand and grade of oil?
Old 04-03-2024, 09:48 AM
Jay S's Avatar
Jay S Jay S is offline
In that first photo I thought it was looking kind of tough also.
Just from that first photo, it was not a better 8620 cam core, it is obviously not a cast cam core either. Looks like a 5150 for 8660 cam core. My guess is a 5150, but I can’t tell those last two apart from the photo. The hard surfacing is not as thick on those cores…IRC, it would have to have pretty minor damage to be reground, it is a possibility though.
It could be the cam surface gave up over time, or it float the valves at some point and started to dig in to the ramp, it does have a good amount of lift. It could also be some needles in the roller bearing are gulled and dragging hard under a load. I suppose it could have even got some contaminates in the oil and cause that too, kind of unlikely though.
Only way to eliminate the lifter as the cause is to press the axle out and look over the needles.
That’s a bummer, at least it sounds like you had a lot of fun with it.
Old 04-03-2024, 09:56 AM
78w72 78w72 is offline
Like Tom said hard to nail down a brand as comp had 3 suppliers. I don't remember what year the 857 "S" lifters showed up as well. I think that was a little later.
May be more identifiable when you pull them out and snap a pic
I bought my 1st set of comp lifters from dave at SD in 2012, had the engine/car running in 2013.. it ran great but had the notorious hyd roller ticking, dave suggested adding some seafoam to the oil to see if it would clean out any debris from manufacturing but it didnt work.
He replaced the lifters under warranty with the "new" S comp lifters that came out in early to mid 2014, replaced them in late 2014 according to my notes. So these lifters werent the shavers, look like my originals from the pics, either johnson or morel.
Is it possible the lifter wheel wasnt hardened right to cause that damage? Pretty sure the OF cams were billet, thats why they require a poly or brass dist gear. Bearings could be bad too but still roll ok under no load?
Old 04-03-2024, 10:25 AM
Steve C. Steve C. is offline
On the all the copies of SD Performance cam cards I have on hand they have either part # 51-000-9 or # 51-000-11
The last number, both the 9 or 11 indicate 'Steel Billet Roller'.
Old information here:
Old 04-03-2024, 01:42 PM
Billet
Old 04-03-2024, 02:09 PM
mgarblik mgarblik is offline
Fortunately you caught this before there was catastrophic damage. The damage you have is manageable. Why did this happen specifically on one lobe? That can be hashed out in these posts forever without a clear answer. As one of the few on the forum who still have little issue with flat tappet cams, this is just one more example that a roller is not a 100% cure for wiped cam lobes. It did enjoy a pretty good life span for a performance engine. In the time period you purchased and installed these lifters, Comp and many others were sourcing lifter wheels and needle bearings from various Chinese vendors. There were a considerable number of failures as we know and everyone was pointing fingers and blaming suppliers. So much so that in this time frame Crower began making all the wheels in house and axles. Also only US sourced needles. That is not the case today as they feel they have found some quality imports for some components. All we can do as end users is try to buy the very best components we can afford and cross our fingers. Hope you can get it all back together and save that camshaft.
Old 04-03-2024, 03:08 PM
tom s tom s is offline
Mike,Comp has not made their own hyd roller lifters for many years Johnson supplied them,Isky and Clay Smith for many years.They went to Ron Shaver Industries here in So Cal to make the S lifters and subbed Morels if out.Many cam company's buy from Morel.Comps new lifters look like Shaver bodies with in house made replaceable cartridges.Actually made by a Edelbrock company.I dont think any of the major cam companys are knowingly buying China made hyd roller lifters.Tom
  #38
Old 04-03-2024, 04:02 PM
Yes, agree Tom. But the components were being sourced from China. Specifically the roller wheels and the needle bearings. The most critical parts of the lifter. Then assembled in the US. Problem isn't specifically China, it's looking for the cheapest source for critical parts with little to no quality control that leads to failures. When your company is owned by an investment group like IOP, (Industrial Opportunity Partners), the only thing that matters is stock dividends and profit. The legacy name is only a name to generate profit. Unfortunate deal for the end users.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
  #39
Old 04-03-2024, 05:40 PM
Shiny Shiny is offline
I'm always interested in how and why stuff breaks.
This must be very frustrating, and I don't minimize the pain of this discovery.
Just thinking out loud with my fingers....
It seems the roller still rolled, so maybe this was just a case of contact fatigue? If so, then it may be inevitable, depending on the design? If the contact stress is high enough, all the hardening and materials quality in the world might not be enough to prevent eventual failure??
And I will always jump on the bandwagon suggested by mgarblik. It's not about being made in China, it's about a failure to manage the design and quality, no matter where it's manufactured. Unfortunately, when you source parts from foreign suppliers, it's way to convenient to blame your own failure on your supply chain. IMO, you buy the parts, it's on you to make sure you get what you need.
  #40
Old 04-03-2024, 10:41 PM
Theres witness marks but you cant catch a nail on it
