Old 03-20-2024, 08:33 PM
SD455DJ SD455DJ is offline
I certainly would use the good RA hood you have for your Formula. Who cares if it's technically correct for a '71/'72 Bird. None of my cars are concours show cars and they all have 'incorrect' replacement pieces on them. Now, if it was a high dollar nuts & bolts restoration, I could understand finding the correct parts. You have a rare and real RAIII Formula that you want to drive and enjoy, so have fun rebuilding it. I want to see it get done myself.
Dennis
The Following 3 Users Say Thank You to SD455DJ For This Useful Post:
  #62
Old 03-21-2024, 01:21 PM
Ramairnacho Ramairnacho is offline
Default non braced hood.
This just popped up and advertised as 1 year only. Im.very confused now. But I know this they are hard to find. Especially in my area.
  #63
Old 03-21-2024, 02:21 PM
grd777 grd777 is online now
You have seen on BAT cars sell for big money, and they were not 100% correct
I say who cares as long as you are happy about the car you are restoring
The Following User Says Thank You to grd777 For This Useful Post:
  #64
Old 03-21-2024, 06:38 PM
RAIV70TA's Avatar
RAIV70TA RAIV70TA is offline
I bought my 1st Pontiac 44yrs ago and became a die-hard enthusiast from that point forward. I was taught by the older guys to "never say never" when it came to how cars were built or optioned back then. I still believe that today. When I bought this car, I figured and still do, that the hood did not come on the car. Having said that, I have found blue paint under the hood vents. The car was originally Atoll. So at the very least, the hood was blue at some point in its life. I also believe that if you're not learning on a daily basis, you're not growing. I did not know about the ridge in the hood inlets, so class is in session! I didn't give the screen bolt holes much thought either. I have both A and F bodies, so I'm always looking for both. I tend to read more than participate, but would like to do more of the latter.
The Following User Says Thank You to RAIV70TA For This Useful Post:
  #65
Old 03-21-2024, 06:45 PM
RAIV70TA's Avatar
The car is worthy of the correct hood and hopefully I'll come across one.
ID:	630808   Click image for larger version
  #66
Old 03-21-2024, 10:52 PM
Default hood
You can always find a non braced hood and simply cut the vents open screen and put ring retains on it. In the past 5 years I have seen only 2 real ra3 hoods for sale but didn't have the knowledge that I now have. I have looked and found nothing. but uncut ones . Good luck finding one. I happy with what I got. Ps. Formula Bruce has correct hardware for the ra hood if you need it
  #67
Old 03-22-2024, 09:50 PM
Definitely worthy of a restoration. Great options, and an outstanding color combo!
  #68
Old 03-23-2024, 11:08 PM
One of my old cars, a 1970 Formula 400, April 1970 Norwood car with original (unbraced) hood. It had the worst bowed hood I have ever seen.
The Following User Says Thank You to eaglesan13 For This Useful Post:
  #69
Old 03-24-2024, 01:34 AM
Default bowed hood
Does the bow cause the hood to lift in the back where it meets the fender edge over the hood hinge?
  #70
Old 03-30-2024, 03:39 PM
No, it had a good fit at the front corner and at the rear corner, it was just bowed badly in the center.
  #71
Old 03-31-2024, 12:10 AM
Default bow
it's hard to tell , but Im.still learning thou.
