Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Smallest turbos for 1800hp 540 combo.
Posting this for a friend with a 540 BBC,(yuk),he's currently running an 8-71 combo but wants to switch to a twin turbo ,blowthrough Domi setup.
His problem is lack of space to fit the turbos, his car is tiny, he wants a max of 1800hp, and water/meth injection will be used because there's no room for intercoolers anywhere in the car. I know the BW S400's will make the power but they are just too physically big, what are the physically smallest turbos available that will make up to 900hp each? I'm assuming he will need T6 flange turbines and can work out what compressor size he'll need from the maps,but I can't find any diagrams of turbo dimensions anywhere.(except MP ,but I know they wont make the power). Preferably not the expensive BB type. Thanks,Taff. |
Precision shows small frames all the way to 1000hp+
http://www.precisionturbo.net/small-...bochargers.php |
V8, yeah thanks, but what size is a small frame in inches? I need to know how long and wide they are so we can measure up to see if they'll fit.
Precision, PT 88's T6
DOC'S TA Turbo 535, CV 1 heads. Built by Cerralli Competition Engines Tenth Anniversary (Van Nuys) restored. Tenth Anniversary Barn Find (Norwood) Both 4 speeds! |
Any thought to mounting them in the back?
The secret to happiness is not getting what you want but rather, wanting what you have. |
Harry has some pretty good stuff in the 1000 each range.
Steve Morris made 1800 hp on gas with Gordon's 509 cid engine using 2 80mm turbos: http://www.smreperformance.com/turbo...r-engines.html He later (see same link) made over 2300 hp with 91 mm units. Tom Vaught
Thanks guys, Torment the car has no room anywhere,it's about the size of an old Anglia,he had to stretch the wheelbase 6" to make the legal 90" rule!
Well 1800hp ought to be a fun ride then... at lease once or twice
Yeah, I've told him he'll have to wear bicycle clips
Bankbook, I've found the PT88 with a T4 flange but can't see a T6 version,got a link to it? Or even better a diagram/pic? Thanks. |
I dont have a link or pics. I did have them spec'd for my build a while back from Turbo69bird (Jeff). Although not commonly found with a T6 flange they are available. Most guys get the T4 because they are using a single set up. They are listed on Precisions website.
