Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Good e-head exhaust valve for boost
Engine builder told me my stock e-head exhaust valves are warped. Who makes a valve that will take the heat?
Ferrea Special Alloy is the only way to go. Call David or Chase over at the Butler's, that's what I use on all my stuff, Pontiac or otherwise.
TQ |
Titaninum works great also.
Marty P. |
Travis.
I see a lot of companies now offering Nitrated coated exhaust valves? |
Titanium, as was said, has been used for years as has sodium filled valves. Both are expensive. Ferrea would be my personal first choice as I have no money. Tom Vaught
FWIW: Eric |
Nobody uses iconel anymore?
Titanium has come down in cost lately; must be coming from Russia or China. Lord knows those Rooskies use enough of it in their submarines, AND they're a major source of the stuff....
Pump gas and hydraulic lifters are for minivans. |
I have Ferrea valves in my heads...no complaints here.
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
FYI: we have found a dramatic improvement in valve & seat durability by using copper-beryllium seats. They have a "softer" landing for the valve and they sink heat away much better. FWIW: Eric |
I have used copper-beryllium seats in some of my Boosted dyno engines with very good luck.
Tom Vaught
Thanks guys, looks like I will go with the Ferrea Special Alloy. Whats the best way to set up the valve guides, I think my builder knurled the guides and reground the stock valves, then I put about 30 miles and 5 pass on the motor and burned the top edge off of the #4 piston.
I have a set of Copper-beryllium Ping eye 2's, I can spin a 9 iron back 10 yds, uphill with those puppies. |
Eric |
Anytime someone wants to "knurl your guide" walk away really fast.
No place for knurled guides in HP Engines, IMO. Knurling creates places for trapped oil, true but it also creates bits of metal that break off the guide walls and wind up in the oil. Bandaid for people who could not afford new guides. Same deal for knurled piston skirts. Tom Vaught
Though they outlaw'd knurling guides back in the 80 's...
Manley also has some good HD ones.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 Last edited by Region Warrior; 12-24-2009 at 01:23 PM. |
We put a custom sized Ferrea 'special alloy' exhaust valve in the CV-1's going on my boosted pump gas 555. The guy completing the motor works on a lot of turbo/centrifugal motors, and wont use anything else because he has had 0 issues with them.
I've been using the Ferrea 6000 in my turbo engines without issue.
I ran 5000 series in the first two engines with no problems. I do run lower boost/power levels than most(15-16psi) but have lots of heat with my small turbos and no intercooler. I've seen near 1800 deg. EGTs at 16psi through the traps. I think the water injection is really helping to extend the life of my valves/pistons. |
