Old 08-18-2022, 11:06 PM
einstein's Avatar
Default Alternator/ignition whine on AM radio band
Non-Pontiac, 95 Silverado with original AM-FM cassette. Son borrows truck, alternator blows apart, he replaces with one from auto parts chain store.
I'm traveling more with the truck, so often looking for something to listen to in unfamiliar cities.
I get an RPM related staticky whine that may also include distributor noise.
I also get horrendous noise while passing semi-trucks.
I'm curious if the alternator or the radio or harnesses are missing some kind of an RF filter.
Anybody here have experience and knowledge about how to correct?
Old 08-18-2022, 11:13 PM
george kujanski's Avatar
First thing is to check that everything is grounded well. Alternator housing, engine to frame, engine to firewall, radio to firewall metal, battery neg to engine etc. Antenna coaxial cable needs to be intact so the cable outer sheath connects well to the radio metal chassis.
George
Old 08-18-2022, 11:45 PM
Sirrotica's Avatar
88-98 Silverado's are notorious for bad grounds, mostly due to corrosion. I own 3 of them and have had weird electrical problems from corroded body, and frame ground points.
Some alternators had a capacitator/condenser on them for radio noise, wondering if cheap reman eliminated it, and that caused radio noise? I actually don't recall one on my 93 though, when I changed it.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-19-2022, 11:59 PM
einstein's Avatar
Thank you, gentlemen.
