Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 09-23-2023, 03:54 PM
wbnapier wbnapier is offline
Default Engine Tools For Sale - Round 1
All together, $140 + shipping from 92024.
Venmo: W-Brent-Napier
PayPal: wbnapier@yahoo.com
1) Moroso Pro Wheel w/ Socket and pointers - $40
2) Total Seal Ring Compressor 4.125 - 4.225” - $10
3) Ring Squaring Tool 4.00 - 4.23 - $10
4) Crank Socket Adapter to Rotate Engine - $5
5) Ring pliers, unknown brand - $10
6) Ring pliers, OEMTOOLS 250B3 - $15
7) Pontiac Dip Stick Installation Tool - $10
8) Pontiac Oil Pump Tube Installation Tool - $10
9) Pontiac Oil Pump Drive Tool - $10
10) Flex / Fly Wheel Hold Tool - $10
11) Camshaft Installation Tool - $10
12) Spark Plug Hole - TDC Tool - $5
13) Spark Plug to Air Compressor Adaptor Tool - $5
14) Piston / Rod Assembly Rod Bolt Rubber Sleeves - $5
15) Spark Plug Thread Chaser - $5
16) Timing Chain Crank / Sprocket Alignment Tool - $10
17) O2 Sensor Socket - $5
18) Feeler Gauges - $5
19) Valve “checking springs” Light - $10
20) Flat and Roller Tappet Lift Tool (Must be used with dial indicator) - $20
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 09-23-2023, 04:06 PM
I forgot a photo. Please see it here.
Name:	Engine Tools 1.jpg
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-23-2023, 04:21 PM
73 TRANSAM 73 TRANSAM is offline
I'll take the degree wheel, crank socket and flywheel tool.
Old 09-23-2023, 06:40 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
I will take
I'll send you a pm
Old 09-25-2023, 12:23 AM
KGTO's Avatar
KGTO KGTO is offline
I'll take:
3- Ring tool
7- Dipstick tool
14- Rod bolt sleeves
16- Sprocket tool
17- O2 socket
19- Checking springs
20-Tappet tool
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 09-26-2023, 06:27 PM
Most sold.
I am starting a new thread with more tools from storage and I will include those not sold here in that thread.
Thank you all.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 09-28-2023, 01:27 PM
Default parts
Just received the pars. Everything is as described and really in very good condition. Thanks.
Old 10-02-2023, 06:13 PM
KGTO's Avatar
Received mine too, very fast and everything looks great thank you!
1964 421 GP-Sold
