Old 04-11-2021, 10:58 AM
66beaumont's Avatar
66beaumont 66beaumont is offline
Originally Posted by 78w72 View Post
do you know what version of lifters they are? original older ones or the "S" current ones?
Motor was built in 2015 so older lifters I guess. Don’t know when they changed. Will get back to it today and continue search for missing piece . Has to be there somewhere. Checked with a few sites and seems no stock on these till June ☹️. I wanted this back on road by end of month! Btw new TKX fits very nicely,just had to massage floor pan a bit towards rear of trans.
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
Old 04-11-2021, 11:04 AM
78w72 78w72 is offline
think thats right around the time comp changed to the "s" lifters. thanks
Old 04-11-2021, 12:08 PM
Formulas Formulas is offline
Just a thought, could those bars be contacting the push rod cover leading to destruction?
And the push rod cover is where the lose parts settled possibly
Old 04-11-2021, 01:18 PM
66beaumont's Avatar
No evidence of contact with valley cover. Will continue search this afternoon for missing part. Found a spare pair of 857 I replaced when engine was new,one had collapsed. Going to pull apart and see if I can find reasons for collapse and reuse hopefully
Old 04-11-2021, 03:02 PM
tom s tom s is offline
66beaumont,your lifters are the newest Comp hyd roller lifters made my Shaver.Tom
Old 04-12-2021, 07:10 PM
Vid's Avatar
Vid Vid is offline
That’s a mess. Sorry to see it. I wonder if the cam itself got wiped out too? Anyway, my sincere “Cam-dolences”, hoping my comments will “lifter” you up!
Old 04-13-2021, 06:20 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Even Comps detachable solid roller lifters link bar seems suspicious to me, one of the reasons I stayed with Crower
Old 04-13-2021, 10:23 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Default Video of why he didn't have more problems
Quick video of why he didn't have more problems and why the Arrow Injuneering Roller Lifter Guide Plate works. IF he had floated the valves because of weak valve springs this could have been a disaster!
https://www.facebook.com/randy.repp....20571751861803
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 04-13-2021, 11:40 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Was the valley pan still on when you first turned the motor over on the stand? Like I said before the missing part could be in the baffle of the valley pan.
Old 04-14-2021, 12:46 PM
Old Goat Racer's Avatar
May I assume these are the old style ?
Everybody knows somthin.
Nobody knows everything !
Old 04-14-2021, 08:25 PM
Yes they are.Tom
Old 04-14-2021, 10:44 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
My old style 857’s from 2010 have the rollers almost covered up by the body.
Like these;
https://www.ebay.com/itm/Comp-Cams-8...epid=192366391
Old 04-14-2021, 10:57 PM
Those were Johnsons.Tom
Old 04-15-2021, 10:48 AM
OK So these are old style. Which is better old or new ?
They prolly have a couple hundred passes on them. Replace with something else ?
Old 04-15-2021, 10:49 AM
Formulajones's Avatar
I'll put this up again for comparison sake.
These are both Pontiac lifters, bought from Comp Cams.
The pair on the left I believe are Johnsons, purchased them through Comp. The pair on the right I bought from Paul K and are the "S" lifters sold through Comp..
As you can see the oil band is much higher on the new "S" version, and is correct for Pontiac. However I've run both of these in Pontiac engines and had no issues with either design, with no oil band modifications done.
Which is better is debatable. Some prefer the known quality that comes with the Johnsons, with what seems to be better internals with more consistent bleed rates. We ran those for about 5 years in a 455 and they were flawless. Many also like the encapsulated wheels, they are much stronger.
The "S" lifters have the oil band moved up and that seems to attract many Pontiac'ers even though I believe the issue is again more related to internal lifter clearances and inconsistent bleed rates as the oil band height hasn't made a bit of difference in anything I've built here. Some don't like the exposed wheels, and there has been instances of those breaking, although I've never experienced that myself. Link bars are pretty much the same between the 2 brands.
Pick your poison.
https://youtu.be/XqEydRRRwqE
Old 04-15-2021, 11:01 AM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Originally Posted by ZeGermanHam View Post
Ugh, so unfortunate. For as much as I like the idea of using roller lifters in my Pontiac, I don't think I ever will. There are just too many stories like this.
All these posts about roller lifter failure sure make me like my old junk solid flat tappet cam.
Sent from my SM-G981V using Tapatalk
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 04-15-2021, 11:18 AM
Dont all solid roller lifters have the exposed wheel?Tom
  #38
Old 04-15-2021, 12:59 PM
PunchT37's Avatar
Pick your poison.
Iv`e got those Johnson`s in mine. Edel round ports, 8.900 pushrod, and HS rockers. Has been to 6500 and 6200 many times. All good so far. Road Paver cam.
  #39
Old 04-15-2021, 02:02 PM
Probably never have an issue with them. Johnson makes a good lifter, with good internals that don't exhibit the noises that so many complain about.
Those Johnsons I pictured on the left, you can tell they've been run. They were in a 455 with eddy round ports and a custom 254/262 @ .050 cam that Jeff Kauffman spec'd for that engine. They saw 6000 rpm many times over a period of 5-6 years that engine was together and thousands of street miles, whisper quiet, they worked perfectly and nothing wrong with them when that engine came out. They'll go back in something in the future.
I have the same hydraulic roller lifters in my 454 Chevelle with a 242/248 cam that have been in there going on 20 years now. That one sees 6500 semi frequently. They work perfectly.
  #40
Old 04-15-2021, 02:06 PM
Nothing wrong with that either. I love solid flat tappets. Daily drive one, and 2 other cars here with them as well. I nitride the cam and run the EDM lifters with lube hole on the face, button it up and don't worry about it.
