I'm wire wheeling my Rally I's and gonna paint them the correct shade of Silver. My question is, what color should the inner ( car side ) of the rim be painted. It seems like it was painted black, but not sure if just road grime.
Jim
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x |
Jim
They get painted the same color silver as the outside of the wheel .
Man is not complete until he's married , then he is finished ! |
OK, thanx. I assume that I cannot harm my steel wheels with a pressure washer, even with very strong direct spray. Thoughts ?
Jim
Why don't you send the wheels out to be sand or media blasted ? You will have a much better finish . The method you are using now will not produce a good lasting finish . Just my 2 cents worth .
I guess it is instinctive for me to try and do it myself first. I value your opionion Jim as I believe you own a body shop if I recall. My wire wheel technique has successfully removed all of the silver paint/rust from the good side of the Rally I. The backside of the wheel is all black and a PITA to be honest. Do you feel it is the final texture of the wire wheel versus media blasting that would yield the difference in a lasting finish ? I could sandblast them I guess if you think the end results will be vastly improved. Thanks for your help
Jim Doran
Wire wheeling any metal may clean it , but it dosn't really clean it . It will not got all the contaniments out like blasting can . You want that fresh , ultra clean metal surface .
Then spray a little self etching primer , followed by epoxy primer . Then paint your wheeels . Looks great and will last a long time .
Actually the rims were black on the back side. Only silver facing out. I have several old MCR articles that also point that out.
