Old 05-14-2009, 07:44 PM
dancolkate's Avatar
dancolkate dancolkate is offline
Default Flywheel ID
Hey folks,
I've got a real nice steel M/T flywheel that I want to use. But I don't know what it came off. The p/n is 5256104 and date code is E176. Any ideas?
P.S. looking at the clutch wear marks, it appears to have had an 11" disc on it
Old 05-14-2009, 08:31 PM
2manyT/A'S's Avatar
Some pics could help.
Old 05-14-2009, 08:56 PM
dancolkate's Avatar
Good idea!
ID:	168588   Click image for larger version
Old 05-16-2009, 01:12 PM
Tom Tom is offline
Appears to be a Pontiac 11" flywheel since the back side of the pressure plate bolts are into the ring gear. Casting date indicates a May 17 of 66 or 76.
Tom
Old 05-17-2009, 10:38 AM
dancolkate's Avatar
Tom
Thanks Tom. I called the guy that I got it from 10 years ago and he confirmed that it came from a 76 T/A with a 400/4 speed. Now I neet to figure out if I can use it on a 74 400 with an M20 behind it. Should I get an 11" clutch setup? Do I have to think about which starter to use and the number of teeth on the flywheel?
Old 05-17-2009, 09:10 PM
superdutybob's Avatar
superdutybob superdutybob is offline
I believe that the hub diameter on the later crankshafts, starting in 75, are smaller. Therefore this will NOT work on a 74 engine if it has the original crankshaft.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
Old 05-18-2009, 04:17 PM
Rack776's Avatar
Rack776 Rack776 is offline
Good Point, It might be a Late & Early 1975 Thing,
My Early 75 build pontiac 400 had the larger ring from the factory,
when I switched to a Later built 75 400 it had the smaller ring like a 1976
Gets me every time -
The mid year switch is always in 1975 it's never as easy as 70-75 & 76-81 for me LOL!,
I got stuck with fixing up 2 cars built in the same year, one built in January and the other in August, I bought a A mid year 75 parts car and a 76 parts car, Its like
roulette to see which car will get the donor parts I found, nothing is ever the same!
Jason Rackawack
1975 455 Trans Am - 1975 Firebird 400
Old 05-19-2009, 06:07 PM
dancolkate's Avatar
You guys are right on! Won't fit!
See anything wrong with throwing it on a Bridgeport and opening up the hole?
