Old 12-12-2023, 09:29 PM
grivera's Avatar
grivera grivera is offline
Default Melonized Gear for Pontiac - New
Has anyone seen this? Randy Repp just posted it on his FB page- it’s a Howard’s Cams Everwear Melonized distributor gear for Pontiac. Good deal if quality and a third option for roller cams:
https://pontiacspeedshop.com/howards...ributor-gears/
Nice to see new products for this addiction of ours…
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 12-12-2023, 10:18 PM
gtospieg gtospieg is offline
I'm pretty sure melonized gears for Pontiac have been around for a while.
Old 12-12-2023, 10:27 PM
grivera's Avatar
I hadn’t seen one available- can you post a link?
Will Rivera
Old 12-12-2023, 11:10 PM
Tim Corcoran's Avatar
I never saw a melanized distributor gear for a Pontiac until now. It seems they only make them for a .500 shaft nothing for a stock distributor.
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 12-12-2023, 11:38 PM
jhein's Avatar
jhein jhein is offline
The Progression Ignition distributor I bought around two years ago had a melonized gear and it was .491
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 12-13-2023, 06:58 AM
Formulajones's Avatar
Yeah theyve been around for a while now for pontiac. I mentioned it maybe a year ago when the subject came up. It's what Ive used on all engine builds of other brands for a really long time.
https://youtu.be/XqEydRRRwqE
Old 12-13-2023, 07:02 AM
grivera's Avatar
Which is better for a steel geared roller cam - the polymer or melonized?
Will Rivera
Old 12-13-2023, 08:10 AM
ta man ta man is offline
Great distributor! Love mine!
Old 12-13-2023, 12:07 PM
The ad says for .500 shaft and is good for flat tappet and Hyd Roller cams. Doesn't say solid roller?
https://progressionignition.com/prod...ap-distributor
Tim Corcoran
Old 12-13-2023, 12:20 PM
77 TRASHCAN's Avatar
Ernie, did you get to race, ANY, in 2023???
Shut it off
Shut it off
Old 12-13-2023, 01:14 PM
First time in 20 years I never made it. I did manage to take an old friend for a ride a month ago. He has a supercharged Mustang..fast car great highway car not set up for the quarter mile. Took him for a drive around town..showing him how mellow it is...he asked me how high the engine can rev 5000 rpm?, I told him well over 6000 rpm. ToId him lets head out of town and lets see how its working.I had my street tires on, Nitto's heated them up for a second, took off from a standstill and rolled into the throttle hard..hazed them for maybe 20 feet and fully hooked went maybe 1/8th of a mile then slowed down...totally blew his mind. It was probably the quickest the car has ever been on the street.
Sorry about the hijack to the OP..
The Following 2 Users Say Thank You to ta man For This Useful Post:
