Old 04-18-2021, 01:18 AM
ripper1991 ripper1991 is offline
Default 2nd Gen Experts Correct me on what i have wrong
Regarding what my memory serves as correct on 2nd gen camaro and firebird exterior sheet metal that is the same and can be used on either vehicle.
Roof
Decklid
Filler panel between rear window and decklid. Thats all.
I was informed yesterday due to the fact i dont own a hot rod shop i dont know what im talking about.
FWIW The same individual told me he used doors from a firebird on a camaro and they worked.
i admit i dont remember a lot of pontiac info like i used to but set me straight on the above. thanks brian
Old 04-18-2021, 02:04 AM
Norwood's Avatar
Norwood Norwood is offline
You correct on the second gen sheet metal. Second gen Camaro and Firebird doors could be bolted on but have completely different body lines. 1st gen doors can be interchanged 67-68. 69 doors will also interchange
Old 04-18-2021, 10:14 AM
Brewster's Avatar
Brewster Brewster is offline
times 2
Old 04-18-2021, 01:08 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Not really exterior....but as I understand it ..complete floor and trunk pan rocker panels are also shared.....
Old 04-18-2021, 08:50 PM
NOT A TA NOT A TA is offline
Not sheet metal but the center section of the three piece rear spoilers interchange.
John Paige
Lab-14.com
Old 04-19-2021, 01:48 AM
Aus78Formula Aus78Formula is offline
Basically any parts on ebay listed for both, assume just for Camaro.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 04-19-2021, 05:54 PM
unruhjonny's Avatar
Roof
Decklid
Even though I don't consider myself an "expert", i know enough to be blunt;
The guy you spoke with is an IDIOT.
lol
You are correct.
quarters, doors, fenders, hood all different.
I believe you can use Camaro doors on a Firebird IF you swap on Firebird door skins.
on the other hand, if that bozo used Camaro doors it either looked terrible, or he used them on a Camaro
1970 Formula 400
Old 04-19-2021, 09:06 PM
Nope, Firebird skins won't fit on Camaro door inners.
Old 04-19-2021, 11:25 PM
unruhjonny's Avatar
/\ ok
1970 Formula 400
Old 04-27-2021, 09:03 PM
thank you to those who responded
