Compression Test Numbers - what to expect?
I am about to do a compression test on the 462 11.5:1 motor in my signature.
What sort of compression numbers should I expect ?
1981 Trans Am - Dark Maple Metallic 1976 Pontiac 455(462), Kauffman Northwind Intake, Performer RPM Eheads, 11.5:1 compression, Crower 60919 cam, Venolia domed pistions, Dougs Headers, Pypes 2.5" Dual Exhaust/X-Over, Solid Body Mounts, GenIV SFCs, FiTech EFI, Walbro 400lph pump, TanksInc. EFI tank. MSD 6AL2, MSD ProBillet. |
a lot depends on the cam.Tom
I think once you have all Cylinder pressures marked down you will find your issue!
Probably over #175 & up I would be happy with. I know that motor very well & it was very strong! John
1970 GTO Judge. New times 10.60/126 with a 1.45 60ft. 2002 FIREHAWK-conv. 6-sd. 1969 Carousel red Judge Ram Air IV 722 heads. 4-sd. Black interior. |
Hi John !
It is still very strong after switching from the solid race cam and lifters to the more street friendly 60919...and to match the lower stall and gears (3:08) But the #2 plug is getting heavy carbon, so I am testing to check it and get reference #"s recorded. |
It will be interesting to see the #'S from Cylinder 2 compared to the rest. Did you change the valve seals. Can you pull the cover on that side & do a visual after you check the compression. Never know I've seen seals lifted off the seat.
John
Mine used to do 225'ish with a 246/253 cam. 230 to 235 with a 230 cam.
I replaced all the valve seals as the new springs had smaller inner diameter. They are the blue/ metal type. But that will easy to check.
Time to upgrade!
Maybe it's time to upgrade to a 535!!!!!
I'm thinking to upgrade to an all Aluminum block with a pro charger set up! There's a IIAII pump gas motor with SD Daves top end PKG. in your area!!! I'm thinking about a street combo with a pro charger & 1000hp.
He he... I am at Stormin's now...he is not home...maybe I will just hook up his trailer and do another swap
Ha ha! That's a nice trailer eh! Nice Greek Colours!!!! Yes he's got a beauty all Aluminum in his Firebird now!
I'm Jealous!
Your strangling those heads with that Performer Intake you know?
Color of your car is amazing.
The RPM was not in stock and I was rushing to make the Bandit Run. With my flat air cleaner cover, I had maybe 1.25in. clearance with the turbo hood. Figured with a bubble top lid (which it should have) I would lose that clearance. Even though the motor is used to running on the track at 6000+ , I would not be taking it there driving around town. Not an expensive upgrade when I need it however. I had to cut the intake .080 to get it to fit, so no return is possible either. |
