Old 11-26-2022, 03:41 PM
Default Air cleaner housing
I bought this housing off of a guy today along with a factory 4 barrel manifold for super cheap. He gave me a bunch of other parts, too. Nice guy. Anyway, can someone tell me what car it likely came from? I’m trying to make the engine compartment look more like stock. I know that this isn’t the one for a ‘67 4 barrel. Those seem to be unobtainium. But I’ll have the stock(ish) intake, a rebuilt quadrajet and maybe this air cleaner. Then we could attach the super rare bracket for factory cruise with a 4 barrel (ours had the 2 barrel originally) and get that going again. The cruise control the final thing to fix on the car. Manifold part number attached and pic of the cruise control to Quadrajet bracket that we scoured the web for a year to find.
ID:	602635   Click image for larger version
ID:	602636   Click image for larger version
ID:	602637   Click image for larger version
ID:	602638   Click image for larger version
Old 11-26-2022, 04:10 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Intake, I believe, is 68 or 69.
Air cleaner, couldn’t tell you what car it’s from, but methinks it’s 71 and later vehicle. I think thats when the qjets had the big vent housing on top that went into the corresponding hole in the base.
costs too much
Old 11-26-2022, 04:50 PM
AG's Avatar
AG AG is offline
1972 had a painted lid, I think 1971 was still chrome.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 11-26-2022, 07:03 PM
So, to find a filter for it, should I search a 71 GTO on Rock Auto?
Old 11-26-2022, 07:18 PM
SD455DJ SD455DJ is offline
It looks like a '70/'71 B-body (& GP?) short single snorkel housing as it has the small hole for the round vent stack on '70 Calif. cars and then '71 all-states. The chrome lid may have come with the 455HO on the B-bodies (North would know for sure) and I believe the filter is the old AC 212 number (like for the GTO's).
My '71 Bonneville came with the same air cleaner except with a black painted lid.
Oh, 1968 intake manifold, btw.
Dennis
Old 11-26-2022, 08:12 PM
Half-Inch Stud's Avatar
68 if it is a Pontiac. could that be a chevelle assy?
Old 11-26-2022, 08:17 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Going by the position of the breather filter hole it’s a Pontiac. Looks to be a 68 GTO unit. Nice score!
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 11-26-2022, 10:05 PM
Here is the '68 single snorkel air cleaner on GTO's and 428HO's. The snorkel is longer on these and aren't double flared at the snorkel opening like the OP's unit.
Dennis
ID:	602655   Click image for larger version
ID:	602656   Click image for larger version
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 11-26-2022, 10:28 PM
Will expand on what Dennis mentioned earlier, the common short snorkel aircleaner in the original post came from one of the following:
-70 Pontiac B series with evap emissions. Not with the 455 XF engine (dual snorkel)
-70 Pontiac GP with evap emissions & 400 4 bbl engine.
Many '70 Federal emission (non evap emission) Pontiac 4 bbl engines also received this exact aircleaner base but with a plastic plug in the evap vent hole.
-71 & 72 Pontiac B series with 400 4bbl engines as well as 455 engines (standard in Grandvilles).
-71 & 72 Pontiac GP's with 400 4bbl engine.
'70-72 GrandPrix SJ's as well as Model J's w optional 455 engine received the dual snorkel aircleaner, same as same year base 400 4bbl GTO & 455 D port GTO.
Last, NO chrome aircleaner lids were installed on Pontiac V8's after the 1970 models.
The above specific chrome aircleaner lid was used from '68-70 on most (but not all) Pontiac 4bbl engines. The chrome plated '67 Pontiac AIR aircleaner lid is a different stamping, shared on some Chevrolet air cleaners.
The Following 4 Users Say Thank You to 'ol Pinion head For This Useful Post:
Old 11-27-2022, 08:36 AM
Suppose the image shows a 67 lid?
Old 11-27-2022, 12:38 PM
Just taking a look at another housing that he gave me, and it appears similar. Found the filter element inside and it seems to fit the first one. It’s 11” ID, 13”OD, and a hair over 3” high. Obsolete part number it appears. I looked at the usual vendors and was surprised to see how inexpensive a new one is.
ID:	602677   Click image for larger version
ID:	602678   Click image for larger version
ID:	602679   Click image for larger version
Old 11-27-2022, 01:12 PM
66sprint6, That looks like a '73-up A & B body 4-bbl air cleaner unit. They also use the AC-212 filter.
Dennis
Thread Tools
Display Modes
