Bill Hirsch engine paint
Anybody used Bill Hirsch engine paint with a spray Gun?
I like to paint my bare metal 389 engine and like to have some feedback about the Bill Hirsch engine paint. Thx for any feedback
1965 Bonneville 2 door coupe nightwatch blue AZ car 1965 Bonneville convertible starlight black 1966 Star Chief Coupé 1965 canandian Parisienne custome sport convertible AZ car. „Sold“ 1977 california Firebird Esprit [/SIZE][/FONT] |
Yes, I use it all the time.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Bill Hirsch
Is it difficult to spray ? Read a few bad stories about with long drying process ..shrinkel paint ..
I bought a quart for spraying with a HVLP spray gun
No, it sprays pretty easy. You definitely want to thin it though. Don't put it on too thick when spraying. Several light coats will cover well and it will dry quicker. I only use a thin coat on the exhaust ports and use VHT header paint in a cast finish underneath first. I also put a light coat of Duplicolor engine paint primer on the rest of the engine first before spaying the Bill Hirsch color.
I think you'll have to reduce it with something, pretty thick stuff. And if you are using something like a PPS system check to make sure the metallic will pass through the lid screen. (if you are using one of the metallic pontiac engine colors).
I called them on the Rattle can stuff. Told me to use primer first on the steel parts and spray direct on the cast parts.
I can’t say enough good things about the Hirsch engine enamels. I would definitely say spray over brush, no primer, no reducer if possible. Spray vs. brush looked night/day to me. A 1.4 HVLP should be fine, I made a 1.3 RP work (un-reduced).
No primer on cast (iron or aluminum). They say you can reduce with Xylene (small amounts), but you probably won’t have to. Flake size is impressive, definitely looks like a quality micro flake. I mixed acetone in some leftover paint and was surprised as it reacted and swirled around. Uniform micro flake. Color looks great in person. I wasn’t fond of the real silvery looking light blue from some of the go-to rattle cans (‘68 in pic). |
