Motor mount help
I swapped a 73 455 into a 70 gto that had a 400 in it.The passenger side frame mount bracket is alot shorter than the driver side and it will not line up right the driver side is fine.Can somebody please help.
A bodies up thru 72 used the 2 bolt motor mount with corresponding frame mount for 400 cubes and less. 455's got the 3 bolt engine mount with a matching frame mount starting in 70. That is my understanding. I am somewhat new to the A body scene, tho.
Are you mixing a 455 3 bolt engine mount with a 400 frame mount? What applications did the motor mounts and the frame mounts come from?
"...ridge reamer and ring compressor? Do they have tools like that?" |
if I recall right, the 455 needs different motor mount frame brackets and different motor mounts.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 05-27-2017 at 06:43 AM. |
Your 455 will have the motor mount holes in the block that will work with the 400 motor mounts.
Im using the butler 2 bolt poly motor mount with the factory 400 frame brackets.the passenger side is to short will not line up at all plus if it did oil pan will hit cross member on that side.never had a problem with the 400 moto.
Yes but the passenger side will not line up .plus if i it did looks like it will sit to low
A buddy of mine had the same problem with Butler poly mounts. Had to put rubber ones in.
http://www.machdevelopment.com/album...775/527566.htm |
I have the same deal. 455 in a 69 lemans I have the butler poly mounts sitting on the original 350 frame brackets, works great for me.
Sometimes you have to wrestle the engine around a little to get the bolts in. Go ahead and bolt the engine down and see if its sitting level. regardless of what it looks like I don't think you should be having a problem.
