80 # Oil Pump ?
Anybody know the diff. between a Melling and a Sealed Power pump? Summit shows the SP at $9 cheaper.
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I'm guessing there's probably subtle differences in the machining. You could probably buy the sealed power and put the 9 bucks toward the heavy bottom plate, the checkball mod and the other reworked all those pumps need. Somewhere on here there's a review I did of the melling select pump.
I used to buy the 60 psi pumps (when everyone HAD TO HAVE the 80 psi oil pumps).
Price difference for the 80 psi 455 SD pumps was quite a bit higher as everyone wanted one of the things. I used to buy the 80 psi Spring and the Extended Spring Retainer Cup (from Melling) and swap the parts. ($5.00 for the 80 psi Spring and the Extended Spring Retainer Cup) and 10 minutes of my time and sold a bunch of the "455 SD Oil Pumps" for a nice profit. BUT I had access to a Melling guy who would sell me the parts as I was a WD for them. Now some people are swapping the factory oil pressure ball for the 9/16" ball (a Butler Modification). The 455 SD spring is so long it maybe drops the psi in the system with the smaller ID ball a slight amount BUT the check ball controls the by-pass function of the oil pump. The spring sets the running pressure. Just saying. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
An "old timer" once told me just put a .060 washer under the spring and ya got a 80# pump.
Pros/cons ??
I put a .100 washer between the end cap and the spring gives me about 70 PSI
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
We use .060-.120 worth of shims in the 60# pumps all the time. Not sure I would say adding a shim makes it an 80# pump. The 60 and 80# pumps are set up to have similar oil pressure at idle. Adding a shim to a 60 lbs. pump will raise pressure across the board. So you will have more pressure at idle with a 60# spring and shim than a 80# pump without a shim.
I don't understand. Unless the engine idles at more than 60 psi there shouldn't be any difference.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Folks should realize here that the additional pressure is not needed, and it robs power from the assembly. Also consider that the distributor gear has to drive the pump, which is driven by the camshaft and timing set.
So you are loading the distributor gear harder as well as the timing chain and gears. I've found that these engines, when correctly clearanced and assembled do NOT need more than 60PSI oil pressure. Even the "high end" full race engines I've done well over 700hp use stock Melling 60PSI pumps in them with zero issues in long term service. In any case an 80 PSI pump would be over-kill in a street engine build and just knock the distributor gear out quicker......FWIW.......
The Following 4 Users Say Thank You to Cliff R For This Useful Post: | ||
I always get smiles from the teams when I show up in Pontiac racing apparel. |
Where does a guy find one of these .060 shims ?
To put it in simple terms; both pumps are designed to have 20 psi at idle and 60 or 80 lbs. at high RPM. When you shim either spring it increase the pressure across the board.... So now you might have 25 psi at idle and 70 or 90 at high RPM.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
We buy ours from ARP.
Paul: Your statement said that by shimming the spring you would increase the idle PSI. As a properly operating spring and ball have no effect until the relief pressure is met (either 60 or 80 PSI) how would shimming the pump increase idle pressure?
TRUE. LOL!
Tom V.
It’s so interesting that many of the SS guys who run 3” mains build for .002” max on the rods and mains and free up a bunch of hp by running only 45 psi and without issue.
I'm not sure on that..... Depending on the amount of shims we usually see 5-15 psi increase across the board.... Maybe we are doing something wrong?
Would you have a part number or a link ?
Thanks, OGR
ARP 200-8643
