Old 01-27-2023, 03:13 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Originally Posted by Kenth View Post
160°F is 71°C.
Hope you´re not running 20w50 engine oil.
Reading this paper may be an eyeopener:
https://www.widman.biz/uploads/Corvair_oil.pdf
FWIW
I base my actions on years of real world experiences. Not some eggheads paper. The article does not consider bearing clearances. My machinists sets my motors up to the loose side of the specs so these large journal crankshafts will live. I use 20w50 VR1 oil and 160 thermostats. Won a bunch of racing events and my motors seem to like it. I will stick with what works for me.
The Following 2 Users Say Thank You to Bruce Meyer For This Useful Post:
Old 01-27-2023, 04:22 PM
burd's Avatar
burd burd is offline
I use a 160°. Works for me. I don’t overheat up at Dreamcruise
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes
F ire B irds
Old 01-27-2023, 05:21 PM
geeteeohguy's Avatar
160 in all my Pontiacs for the past 45 years. No problems.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 01-27-2023, 05:51 PM
burd's Avatar
160° thermo was part of the Royal Treatment.
F ire B irds
Old 01-27-2023, 06:46 PM
mchell's Avatar
mchell mchell is offline
If I be were driving my car daily in cold climate winters, I might use a 180-195
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 01-27-2023, 10:00 PM
Formulajones's Avatar
Yep, I run 20-50 and have for decades, which has worked perfectly fine. Don't even bother changing viscosity for the winter months up here in Prescott, which by the way gets down into the upper teens at night. Both daily drivers run that viscosity with 160 stats.
What should be taken into consideration when worried about viscosity is the pour ratings. Basically an indication of it's flow abilities at cold temps. Many "good" 20-50 oils today have excellent pour qualities, some are even better than the cheaper 10-30 oils on the market that many people are using. Ponder that for a second.
https://youtu.be/XqEydRRRwqE
Old 01-27-2023, 10:29 PM
grivera's Avatar
grivera grivera is offline
I use Brad Penn 20W50 in mine. Any idea what other oils with same viscosity have similar pour ratings?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 01-27-2023, 11:03 PM
Let me see if I can find the chart and I'll post it. There are quite a few that have good pour ratings.
Old 01-27-2023, 11:13 PM
Here's an older chart. I'll see if I can find a more current one that has more oils tested. I think specific brand oils should have a chart of their own as well. But this gives an idea of the vastly different pour points, even among the same viscosities. Years ago I would have never thought they would be so different.
https://mcgeerf.tripod.com/americans...coil/id17.html
Will, isn't Brad Penn now Penn Grade? Or is it the other way around? Pretty sure that ranks right up there with other high end oils like Amsoil, Royal Purple, Red Line, Mobile, etc....
Old 01-27-2023, 11:19 PM
grivera's Avatar
Oops - you’re right- I meant Penn Grade but in my head it’s still Brad Penn
Thanks for the link!
Will Rivera
Old 01-27-2023, 11:36 PM
I do the same thing, I can never remember lol
Old 01-28-2023, 12:51 PM
Kenth's Avatar
Kenth Kenth is offline
Any lubricant company has the specifications on their sites to compare.
https://penngrade1.com/wp-content/up...-Oils-2022.pdf
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-28-2023, 01:21 PM
roy381 roy381 is offline
Is there preferred brand of thermostat?
Old 01-28-2023, 01:51 PM
Formulabruce's Avatar
I used to run a 160, but with the factory top rad support cover I run these. No need for air bleed unless your hose goes down hill off the neck. YES you Can get these still, GM Ran these in S-10's as I recall.
Not sure this will pacify the "boil" the oil folks though LOL.
Old 01-28-2023, 02:13 PM
Kenth's Avatar
Good for you.
Not everyone have an engine built by your machinist, i´m sure he did a good job for your racing engine.
Also, if you haven´t noticed, this is the street section and lots of folks here run with factory clearances and where 20w50 and 160°F thermostat is less desirable.
This is, among other things, what the article is about.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-28-2023, 05:43 PM
Good for you.
FWIW
The car Im talking about is a street car. Pump gas and I drive it at least once a week. I used to have a race car. It had no thermostat.
Old 01-28-2023, 07:29 PM
72projectbird's Avatar
Pfft hahahah
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #38
Old 01-28-2023, 11:41 PM
carbking's Avatar
carbking carbking is offline
Just answering the OP's question - 195 in Pontiac and both Fords, and everything else I have owned for the last 30 years. No issues. And better fuel economy than most report.
Jon
  #39
Old 01-29-2023, 12:00 AM
tom s tom s is offline
I can give a tinkers damn what the factory did! I have been running 160 for decades and not changing!FWIW,Tom
  #40
Old 01-29-2023, 08:24 AM
Cardo's Avatar
Cardo Cardo is offline
180 with functioning factory air. No problems at all, including sitting in traffic with air on. Recored factory radiator too. Using a high flow thermostat.
"I know just enough to keep me here, but not enough to get me out"
