Old 09-13-2021, 11:24 AM
RA1John RA1John is offline
Default Intake Manifold Removal: Best Way to Drain Coolant from Engine
When removing an Intake Manifold, what is the best method for removing coolant from the engine so as to reduce a mess on the top end?
- Disconnect lower Radiator Hose (at Radiator) into a large container
or
- Drain engine coolant from pipe plug at lower rear RH side of block
(near Oil Filter).
Thanks.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 09-13-2021, 12:11 PM
tom s tom s is offline
Your radiator should have a petcock drain in the bottom somewhere,might be hard to see if you have a shroud.Remember to pull the cap when draining.Tom
Old 09-13-2021, 12:30 PM
Murf Murf is offline
What Tom said. Jack up the rear of the car slightly.
Murf
Old 09-14-2021, 02:54 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Just use the radiator petcock. Draining from the radiator is able to remove most of the coolant until the level drops to below the timing cover, roughly. At that point, you'll need to break loose the block drain plugs to drain the rest.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 09-14-2021, 03:06 PM
Formulabruce's Avatar
No need to do the block plug for an intake swap. Don't need fluid that low.
Old 09-14-2021, 04:24 PM
Stuart's Avatar
Stuart Stuart is offline
Right. It just needs to be lower than the level of the intake. Use that petcock on the radiator, and assuming the coolant is in good condition catch it in a clean bucket so you can reuse it.
Old 09-14-2021, 05:15 PM
padgett's Avatar
padgett padgett is offline
For an intake I usually just use a siphon hose in the rad inlet and a 5 gal bucket.
Web Site
