Starter Support Brace
Need to change the starter on my 69 Bird with a 400. It has a brace bolted to a stud on the back of the starter and then bolted to one of the motor mount bolts. Do I need to completely remove the motor mount bolt or can it be just loosened enough to swivel it out of the way to remove the starter?
Loosen and swivel. Not going to hurt if you take the bolt completely out. Just make sure the other is tight!
The Following User Says Thank You to JSuchma For This Useful Post: | ||
