Disc conversion
Working on a 64 Catalina and I'm trying to source parts for a front disc conversion. I was told that Scarebird was a good source for the brackets until I learned that he's closing shop and not producing them anymore for the Catalina. What is the next best source for brackets or the whole kit, other than MPB?
Ames.
Wasn't expecting that reply. I'll give Ames a call because I'm not seeing the brackets in the catalog. Thanks for the tip.
Here's the link in the online Ames catalog for disk brake conversions: https://secure.amesperf.com/qilan/De...A&web_access=Y
I don't think Ames' kit comes with a master cylinder, booster or proportioning valve. I bought Master Power Brakes' kit and it came with everything for my 1964 GP.
The Following User Says Thank You to Goatracer1 For This Useful Post: | ||
The booster they use is too small for the master. Is the rotor they use proprietary? no 11" 5 on 5 I know of... Last edited by Scarebird; 11-01-2022 at 08:12 PM. |
I don't know what they use in the front but the rear were Jeep with the center hole machined bigger. I would think the front are off the shelf .
Yes, we have a few left - they are on the website.
My thoughts are.. if Scarebird doesn't have it, you don't need it. I bought my disc set from him and haven't regretted it at all. Had one problem which was taken care of and from then on, the front disc setup has run perfectly. So much better than those drum brakes ever thought of doing. Best move I ever made concerning the front brakes on my 66 GTO. The second best was not having to change out the front drum brake spindles.
Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
Did 62 Catalina Ames frt disc
Master power brake booster and master Stops perfect
2008KRE Q16 Winner 2014 atco raceway doorslammer winner 86 grand am tube car 8.95 @152 455 eheads solid flat tappet cam Hoffman Racing building and racing Pontiacs for 35 years |
Did their master and booster bolt right in or require modification?
Bolted right in no modifications
Thread Tools | |
Display Modes | |
