70 Gto AC vent door missing piece.
I'm trying to locate the elbow that's stapled and mounting ring for the passenger side ac vent mechanism.
I have no clue what it's called so I can't search it up. Any help would be appreciated. I'm hoping I don't need to buy the entire vent setup and can just get the 2 pieces I need. Thanks! |
I should have a 69 one...
Scott |
One of what? The entire unit or the elbow and mounting ring? I still would like to find out what the technical name is for future reference to this part. |
Please re-read my first Post. I think you misunderstood my question. I am attempting to see if I can buy the elbow and ring alone. I am NOT looking to buy the entire assembly. If I am stuck buying the entire assembly they are easily available from multiple sources. I would think I can just buy the pieces I need but honestly I don't know what to call it in a search bar. |
Well
75.00. All or pieces Sorry |
I am not sure why I didn't get notified about your reply by my email. I am just seeing your message now.
I ended up finding the missing pieces still attached in the car. It seems somebody ripped out the vent door assembly and the elbow and ring were still in the kick panel cavity. It just damaged where the staples were. An easy fix. I just have to test my vacuum actuator now. Do you know if the vacuum actuator on your unit works? I'm not very sure how to test the 2 different ports |
Test
It holds open
Under vacuum With 4 lbs vacuum Gauge shows 15 Holds down to 4 Scott Last edited by Scott Thelander; 11-07-2022 at 11:38 PM. |
I will work on removing it from the kickpanel area and see what condition it's in. If it's unusable I will message you about buying yours. |
I finally got around to removing the inner fender and ac box. I removed the 3 screws and took the elbow out. Everything is in working condition.
This Thread can be deleted. |
