Old 09-21-2022, 07:00 PM
1_Wild_Cat's Avatar
Default Location for Hood Emblem on a 64
Hi Everyone -- My 64 GTO came without a hood and I ended with the steel reproduction (which is very nice). The new hood doesn't have the holes for the front arrowhead.
Does anyone out there have a template?
Thanks.
Old 09-22-2022, 08:57 AM
chrisp chrisp is offline
Inner structure may have the cut-outs for the pal nuts.
Old 09-23-2022, 10:09 AM
1_Wild_Cat's Avatar
Thanks - I didn't think of that. It probably does but I'll have to check.
Old 09-24-2022, 11:26 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
If you need measurement I can probably get it to ya but not till mid sunday.
Have 2 hoods outside just no time to get to them today.
64 Lemans hardtop
4spd, buckets
Old 09-24-2022, 01:57 PM
1_Wild_Cat's Avatar
That would be great. I won’t be needing them for a week or so. Thanks for the help.
Old 09-24-2022, 02:11 PM
Dick Boneske's Avatar
There is no provision on OEM '64 GTO hoods for PAL nuts. the emblem is secured by sleeves over the two studs on the emblem.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-25-2022, 03:56 PM
Lemans64's Avatar
I used a piece of masking tape on the hood, marked the spots where holes are and then took off and measured. 7.5 for first hole and 9.5 for second hole.
Hope this helps. the hood latch / secondary catch support is underneath of the pins.
ID:	599318   Click image for larger version
ID:	599319   Click image for larger version
ID:	599320   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 09-25-2022, 05:01 PM
1_Wild_Cat's Avatar
Lemans64: Excellent -- Thank you very much for the help. That is exactly the way I planned to measure it and lay it out.
And thanks to everyone for their comment/help on this.
Old 09-25-2022, 05:14 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
That is a clever way to measure it. I use my wife's cloth measuring tape for that sort of thing. She uses it for sewing.
