Date Code question
What does the letter "K" represent on a starter? Oct or November (i.e. was "I" skipped in the sequence)
Also is the answer the same for block, head and exhaust manifold casting dates? |
On stamped codes, the 'K' is October. ('I' is not used)
On cast in codes (like block, heads) 'K' is November. ('I' is used)
The Following User Says Thank You to johnta1 For This Useful Post: | ||
Thanks Johntal!
One more question on an assembly date....
My 72 GTO has an assembly date of 11C which means third week of November, 1971. Is that the Sunday through Saturday (14th -20th) or 15th day - 21 st day? I know some dont care about these details but I enjoy all the documentation stuff. |
I could be wrong but I isn’t always skipped it was only certain years I have seen casting dates with an I in them
Here’s an example https://forums.maxperformanceinc.com...84#post6150584 The pic I chose may be incorrect may just be a obliterated by the plug but the thread w the manifold describes it and I’ve seen others post about an I being used for date coded parts on certain years
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! Last edited by turbo69bird; 11-07-2022 at 09:07 AM. |
The Following User Says Thank You to turbo69bird For This Useful Post: | ||
I just saw a lengthy post about the I being skipped or not a few days ago maybe in a RAI RAII conversation . And I can’t find it searching now . I is used so much for other things it makes searching it hard. But the basic jist was that it is used in some instances. Wish I could find it for you guys.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
You will find the finsished car assembly date on the build sheet, which could be weeks later. HTH |
Hmm...Always thought that was the assembly date time. Interesting.
If actual final assembly date is in box #10 on build sheet then it was Nov 16 which still falls during the week 11C |
I was there when my truck was built and the documentation is off by a day. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
That pic is of a CAST date code, which would have an 'I' for a month. There was however one year (1967?) that they had a 'M' (for December?). May be the thread you are thinking of. Something about overlapping of model years? (start of 1968 model in 1967, but still building 1967 model year? Like 1st year of Firebird?)
Thread Tools | |
Display Modes | |
