Old 11-14-2022, 11:29 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Trim-Clearance front of rear quarter for tire clearance?
Hey Guys,
What are some ways to Trim-Clearance front of rear quarter for tire clearance and not destroy paint outside of the well on the quarter?
Thanks, Craig
Old 11-15-2022, 08:06 AM
Keith Seymore's Avatar
Die grinder with cutoff wheel.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 11-15-2022, 10:48 AM
JUDGE3 JUDGE3 is offline
once you make that cut, your going to want to rust proof real real well. I let por15 seep between the parts first, then by hand packed seam sealer in there.
If you have a wheelwell trim piece it gotta be cut with it. if you trim a bunch the original trim piece screws may have to move outboard. did all this on my 69 Judge clone when I raced.
Old 11-15-2022, 09:33 PM
CraigG.'s Avatar
Thanks - very helpful - any pictures of finished wheelwell?
Hard to imagine how to make look decent and follow original lines on 72 GTO quarter panel.
Thanks, Craig
Old 11-16-2022, 01:43 AM
ID67goat's Avatar
ID67goat ID67goat is online now
New wheels and tires might be the best way….
Old 11-17-2022, 05:01 PM
I'd hate to permanently transform clearance for that.
Old 11-18-2022, 11:27 AM
was a race thing for me. big soft wall slicks don't tuck into a stock w/w/
Old 11-18-2022, 12:13 PM
Murf Murf is offline
How big of tire are you trying to use? We have a 65 which is fairly limited for tire size. I always thought you could run pretty big tires on the later cars. Maybe I dreamed that up on my own, tho.
Good luck!
Murf
Old 11-18-2022, 06:23 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
How big of a tire? I have a 295 60 on my 69 and it fits fine
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 11-19-2022, 05:08 PM
CraigG.'s Avatar
Issue is on the front where it is rubbing - Mickey thompson bias slick 10.5W. x 28 on 10inch wheels with tubes clearanced for sectional width OK at 13.1
Old 11-19-2022, 05:09 PM
CraigG.'s Avatar
what is your tire? - "I have a 295 60 on my 69 and it fits fine"
Old 11-19-2022, 05:35 PM
Default slicks
yep, thats what I was using as well. couple times. once on an original 69 Gto Judge RAIV in the 1980s and again on my recently sold 1969 Judge clone. clearanced em both. (also had a original 1969 RA3 judge 4 speed.) used cheeter slicks on that one with stock rims though.
the 69 is a different shape of course and I "only" had to clearance the top and taper it in as I went down. done nicely was no big deal. but i'm a street/strip drive the heck out of em type. having to clearance the front as you say is different.
pics?
Old 11-20-2022, 09:40 AM
n20ta2's Avatar
295 65 15 mt et street ss i have adjustable upper and lower control arms . I just moved ot back a touch
ID:	602355   Click image for larger version
Thread Tools
Display Modes
