Old 05-11-2017, 01:15 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Default Jet size?
I have a 66 tripower on a KRE 461
Ram air 4 cam.
3.42 rear. 4 speed
66's seem ok?
I hate cracking open that airhorn if I dont have too.
........I'm just learning as I go.......
Old 05-11-2017, 01:56 PM
Dick Boneske's Avatar
We have .064's in our Butler/Edlebrock 467 with '66 Tripower, Lunati Voodoo HR, using a slightly larger-venturi center carb. If you have a OEM "575" casting # center carb, .064" should be plenty. But, if your plugs look good, stick with the .066's.
End carbs should be good with .073" jets.
BONESTOCK GOATS
'99 Bonneville SE Sedan
