Old 01-22-2024, 09:51 PM
hiyabradHO hiyabradHO is offline
Default 1971 T/A Hood Latch Finish, Heat Riser Chimney Hose and Master Brake Cylinder Finish
Hi,
A few questions:
See pics
1. What is the correct factory finish for the hood latch catch?
2. Who sells the closest to factory correct hose that connects to the Heat Riser Chimney?
3. What is the factory correct finish / color for the Master Brake Cylinder and who sells it?
Thanks!
Name:	Hood Latch.jpg
ID:	626979   Click image for larger version
Old 01-22-2024, 11:40 PM
Formulabruce's Avatar
Part of latch facing you was black Phosphate, the lock mechanism ( pointed part off to right that moves) was Gold anodized.
"Norwood" is our resident expert, and has rebuild many of these latches.
1971 cars had cheap Alkalyd black paint . This was put on at sub assy just to keep flash rust off during transport to final assembly.
Old 01-23-2024, 12:05 AM
Red80TA Red80TA is offline
Might be the photo angle, the hood pop wire looks a bit out of shape. Random question, why was the RH end of it blue, not sure if all years.
Old 01-23-2024, 01:48 AM
Thank you FB.
Do you have any pics to share?
Is the black phosphate finish the same as the bolts holding it in place?
The Following User Says Thank You to hiyabradHO For This Useful Post:
Old 01-23-2024, 10:22 AM
MDSHARK81 MDSHARK81 is offline
I have the same question on the heat riser chimney hose. Is the correct color black coated, or silver? I’ve heard either could be correct?
Old 01-23-2024, 11:50 AM
Norwood's Avatar
Norwood Norwood is offline
Dark manganese Phosphate
The Following 2 Users Say Thank You to Norwood For This Useful Post:
Old 01-23-2024, 12:40 PM
Is that different than:
Caswell BLACK OXIDE CONCENTRATE
Norwood, Are you doing any refinishing and rebuilding?
Old 01-24-2024, 08:44 AM
RAJ7395's Avatar
RAJ7395 RAJ7395 is offline
Got my 4 latches restored by Norwood and they look fantastic.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
The Following User Says Thank You to RAJ7395 For This Useful Post:
Old 01-25-2024, 10:01 AM
Is there any input on Q’s #2 & 3 ?
Old 01-25-2024, 03:22 PM
Judge273's Avatar
Judge273 Judge273 is offline
Not sure anyone sells anything like original hose? What you show looks really close.
Mike/Illinois
The Following User Says Thank You to Judge273 For This Useful Post:
Old 01-28-2024, 09:39 AM
cnc's Avatar
cnc cnc is offline
I have a latch as well from Norwood looks awesome super happy with it....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 01-28-2024, 10:55 AM
grd777 grd777 is offline
car looks very good Chris
Old 02-07-2024, 04:10 PM
Any comments on:
and
Old 02-07-2024, 10:13 PM
What you're calling the "Heat Riser Chimney Hose" should be black. They are available from Ames, part #FN406RB and are called a "Pre-Heater shroud to air cleaner duct."
As for the master cylinder, I believe it should be black. However, it would not surprise me if others opined that it should be gray.
Old 02-08-2024, 09:38 PM
Makes sense that they don't save their pics with names related to their part number.
https://amesperf-parts.s3.amazonaws.com/N180YJ.JPG
https://www.ebay.com/itm/275460995704
Old 02-09-2024, 09:04 PM
I found the "Pre-Heater shroud to air cleaner duct" and the other duct have different part numbers. Were they the same material and just a different length or different materials. See attached.
Name:	Screenshot 2024-02-09 at 2.40.28 PM.jpg
ID:	628265   Click image for larger version
Name:	Screenshot 2024-02-09 at 2.40.11 PM.jpg
Old 02-10-2024, 10:58 PM
Usually different lengths with a certain amount of flex built-in, but not a lot. The parts manuals listed a part number for nearly every application. Later they only had a couple but also the cut-to-length stock that many called for, and probably had a set length for each instead.
It seems suppliers changed over the years, possibly had a few at same time, going from the grey stock to a more glossy black in later years, as well as the grey papery coating. Even a bright silver foil coating appeared but have only seen it in GM service parts, always hard to know what is original in low mileage cars, even when they claim as much.
Old 03-29-2024, 11:08 PM
T/A Fanatic's Avatar
T/A Fanatic T/A Fanatic is offline
FWIW, my '71 master cylinder was black from the factory. Came with the bleeders and had the "EB" stamp as well. Restored by W. Oxley years ago.
Old 03-30-2024, 11:59 AM
tdavidl's Avatar
tdavidl tdavidl is offline
he did mine as well
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
