Old 11-08-2024, 11:18 AM
67Lemons 67Lemons is offline
Default Drop air cleaner base with Quadrajet
I know this is probably a dumb question but what do you do with a drop air cleaner base with a Pontiac Quadrajet that has a vent on the top, I assume you drill a hole to allow the vent to stick through the bottom of the base? I’m not sure I’m calling it the proper name but picture attached of the “vent” for clarity.
ID:	642547   Click image for larger version
Old 11-08-2024, 11:23 AM
78w72 78w72 is offline
Yes drill a hold for it, have to do that on teh universal chrome bases too, they actually have a stamped marking for the hole to knock the tab out.
Old 11-08-2024, 12:22 PM
burd's Avatar
burd burd is offline
Should have a gasket to keep dirt out too on that vent.
Just Say No To 8” Flakes
Unburdened by what has been
Old 11-08-2024, 05:18 PM
Yep drill a hole
2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold
Old 11-08-2024, 05:38 PM
If that’s how little room you have above the air horn then running a drop base air cleaner assembly is totally self defeating !
Old 11-08-2024, 06:52 PM
I drilled a 9/16 hole for mine. Put a smear of my granddaughters’ art gel paint on the vent rim a gently set the base over the carb until it touched the vent. Marked the spot perfectly.
Old 11-09-2024, 10:28 AM
How little room? He didnt mention how much room there is...
Totally self defeating? Pontiac used drop base air cleaners on 2nd gen TA & firebirds due to hood clearance issues that didnt defeat anything... I have a factory TA drop base air cleaner on a q-jet, car runs excellent in all situations as well as runs 11.2 at 121-123mph.
Lots of other 500+hp engines use drop base air cleaners too, he will be fine.
Old 11-09-2024, 01:38 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Been 9.7 @ 139 with a dropped base factory Formula air cleaner....they can't be too bad.
Go fast, see Elvis!
Old 11-09-2024, 06:37 PM
My 78 TA has a modified Shaker base for a Holley/Demon. Has run 10.90s @ 124 pulling the air cleaner element.
The Following 2 Users Say Thank You to Skip Fix For This Useful Post:
Old 11-09-2024, 07:50 PM
Did you see a improvement vs with the air cleaner? what did you do to secure the lid with no element in there, a stop nut & washer?
Old 11-10-2024, 12:00 PM
YES! Enough when jetted for the air cleaner then pulling it out one night at test and tune it leaned popped out the Shaker in my face doing a dry hop! I made a hardware cloth cage and used a 6" air cleaner top to copy the L-88 hold down pieces.
On my 500" IA motor in the Camaro pulling the 14x4" air cleaner off and no base picked up 0.3 seconds!
Old 11-10-2024, 12:39 PM
Neat way to secure the base.
3 tenths from removing the air cleaner base entirely? Wow! Will have to try that, always heard/thought engines did better with a good air cleaner in place, especially the Q-jets that supposedly dont like open elements or direct straight down air supply.
Old 11-11-2024, 05:14 PM
It might have picked up more if I rig up a smooth base and retain it. I know some of the SS guys drill holes and use springs to the valve covers.
Old 11-11-2024, 09:43 PM
I haven’t had time to measure how far the lid is off the drop base but the supposed 3” filter only measures at 2.75” so I ordered a 4” since I have plenty of room under the hood, that should bring the lid at least 3.5” off of the base. I’m thinking it’s fine either way but since I can fit the taller air filter I might as well.
Old 11-11-2024, 09:45 PM
PAUL K's Avatar
Good thinking IMO
Go fast, see Elvis!
Old 11-12-2024, 01:14 AM
242177P's Avatar
242177P 242177P is offline
Suspect Steve is thinking of the more conventional
bowl vent. In that case, having the lid that low would
indeed be self defeating.
Name:	sema fails.jpg
Old 11-12-2024, 10:11 AM
OP has a Q-jet carb...
Old 11-12-2024, 06:08 PM
242177P's Avatar
I know.
Old 11-13-2024, 09:53 AM
Originally Posted by 242177P View Post
I know.
Ok, wasnt sure with the pic of a holley and explaining the low lid being self defeating...
